Windows 10: Fonts problem with Inkscape
Discus and support Fonts problem with Inkscape in Windows 10 Drivers and Hardware to solve the problem; Hello all. I've recently been having an issue with fonts lately. There is a program called Inkscape, which is a free vector graphics editor, and so I... Discussion in 'Windows 10 Drivers and Hardware' started by PriyaAravamuthan, Dec 24, 2018.
  1. Fonts problem with Inkscape
    There is a program called Inkscape, which is a free vector graphics editor, and so I tend to use it very often. When I attempt to create text, problems arise. I use one font, then switch to another one, when a Windows dialogue box opens up - It says: something like:
    Windows Application Error
    The instruction 00x00000eee referenced memory at
    And the rest of the text is blank, same with buttons. I press a button, and all text everywhere in Inkscape turns to rectangles, even dialogue boxes. I exit Inkscape, only to find that all my Desktop icon's names have been blacked out - you can see the silhouette of the letters, and so you can make out the name, but that's it. No text displayed in other Windows dialogues, Task Manager, etc.
    I have asked my father about this - he says it may be a display driver issue, which is triggered by Inkscape accessing the/a font cache.
    Can you all please help me?
  2. NeoSOS Win User
    Fonts
    I found these steps in this forum from back in 2010:
    Step 1:
    I would suggest you to try these steps and check whether it helps in fixing your issue.
    Open font settings by clicking on start, click on control panel, and then click on appearance and personalization, under fonts click on change font settings. And select the font size.
    Step 2:
    If you’re trying to change windows font size then please follow the steps below:
    To change Windows fonts
    1. Open Appearance Settings by clicking the Start button and then clicking Control Panel. In the search box, type window color, and then click Change window colors and
    metrics
    2. In the Item list, click the part of Windows that you want to change the font for. For example, if you want to change the menu font, click Menu in the list. Then, make any of the following changes:
    · In the Font list, click the font that you want to use.
    · In the Size list, click the font size that you want.
    · In the Color list, click the font color that you want.
    3. Repeat these steps for each item that you want to make changes to, and then click OK.
    Does that help?
    NeoSOS, Dec 24, 2018
  3. FONTS
    I understand your inconvenience. We will assist you with it.
    I suggest you to follow the instruction provided below and check.
    Step 1:
    • Download the font type you want to install.
    • Right click and click on install.
    • Check if you are able to view the fonts in documents.
    Or
    Step 2:
    • Open Control Panel.
    • Click on fonts.
    • Now, drag and drop the downloaded fonts in the font’s folder.
    Hope this information helps. If you have any queries, let us know. Will be happy to assist you.
    Syed Md Bilal, Dec 24, 2018
  4. Fonts problem with Inkscape
    Fail to start Inkscape 0.92.2
    • Version 1607 (OS Build 14393.1770)
    • Dell Latitude E7270
    • The inkscape website via https://inkscape.org/en/release/0.92.2/windows/64-bit/
    • It is the first time to install this application i.e no previous release had been installed.
    • Completed a quick scan on my PC with no threats being detected.
    • I haven't installed new software in the last few weeks. The system has been quite stable.
    • First installed Inkscape and the application will not open. Uninstalled the program and reinstalled program with the same issue. Shut Laptop down and rebooted with the same issue.
    Janette Tong, Dec 24, 2018
  1. Fonts problem with Inkscape - Similar Threads - Fonts problem Inkscape
  2. impossible d'installer Inkscape
    impossible d'installer Inkscape: Bonjour, Je n'arrive pas a installer inkscape quelqu'un pourrait il m'aider ? merci d'avance https://answers.microsoft.com/en-us/windows/forum/all/impossible-dinstaller-inkscape/f1a2595c-1367-4d06-b5e2-9ca1e29892f6
  3. impossible d'installer Inkscape
  4. Cannot reinstall inkscape
    Cannot reinstall inkscape: So running inkscape gives me the error Then when I click see in store I get However clicking reinstall doesn't do anything. https://answers.microsoft.com/en-us/windows/forum/all/cannot-reinstall-inkscape/0efda922-0a60-4afa-a254-87a12cb54ef7
  5. Cannot reinstall inkscape
  6. Cannot reinstall inkscape
  7. Inkscape is saving to OneDrive folder and not Documents
    Inkscape is saving to OneDrive folder and not Documents: When I go to export a PNG to This PC -> Documents Inkscape is saving to OneDrive/Documents instead. I don't have OneDrive installed. I don't want to have anything to do with OneDrive. 174830
  8. Font Problem?
    Font Problem?: I have a program, Aldfaer, that shows in the titlebar see image left of the word 'Doneer!' a ? in stead of the €sign. Below in front of '71' and '1700' also a question mark in stead of +/- In my research it appears to be a Dell pc problem because many Dell users have the...
  9. Inkscape installieren?
    Inkscape installieren?: I downloaded Inkscape and was about to install it, but then I was asked "do you want this app from an *unknown* publisher to make changes to your device? That rattled me a little. I downloaded it from the official website, so I assumed that the publisher was verified. Am I...
  10. Inkscape Issues
    Inkscape Issues: After installing Inkscape I am not able to edit Inkscape Preferences. My Operating system is windows 10 ( english). However the Inkscape interface is always in spanish. I would appreciate very much any help....
  1. inkscape font MIcrosoft
  2. inkscape will not download fonts after windows update
  3. how do i emport fonts to inkscape
  4. fonts not working in inkscape,
  5. inkscape fonts issue,
  6. windows fonts inkscape,
  7. inkscape dont reconize fonts on windows,
  8. uploading fonts to inkscape from windows 10,
  9. downloaded fonts not working in inkscape,
  10. problems with fonts in inkscape,
  11. uninstalled fonts still appearing inkscape
