Windows 10: Freezing after right click in desktop need help!! Major software or hardware problem!!...
Discus and support Freezing after right click in desktop need help!! Major software or hardware problem!!... in Windows 10 Gaming to solve the problem; Will either; Freeze for 2-10 seconds just hit ctrl alt del sign out sign back in still does it no pop-up menu. Refresh the desktop really fast can do... Discussion in 'Windows 10 Gaming' started by ChristopherPiasecki, Feb 4, 2023.
Freezing after right click in desktop need help!! Major software or hardware problem!!... - Similar Threads - Freezing right click
Desktop freeze when right clicking a program in the desktop
in Windows 10 GamingDesktop freeze when right clicking a program in the desktop: My pc was working normally after while i faced a problem, when i right click a program in the desktop the desktop will freeze, also i saw that programms that was installed on Hdd drive when i right click on them the context menu appear without any problem, but when i right... -
in Windows 10 Software and AppsDesktop freeze when right clicking a program in the desktop: My pc was working normally after while i faced a problem, when i right click a program in the desktop the desktop will freeze, also i saw that programms that was installed on Hdd drive when i right click on them the context menu appear without any problem, but when i right... -
in Windows 10 BSOD Crashes and DebuggingFreezing after right click in desktop need help!! Major software or hardware problem!!...: Will either; Freeze for 2-10 seconds just hit ctrl alt del sign out sign back in still does it no pop-up menu. Refresh the desktop really fast can do this repeatedly till either freeze or desktop refreshes no pop-up menu.Show menu immediately, slight chance of this happening.... -
in Windows 10 Software and AppsFreezing after right click in desktop need help!! Major software or hardware problem!!...: Will either; Freeze for 2-10 seconds just hit ctrl alt del sign out sign back in still does it no pop-up menu. Refresh the desktop really fast can do this repeatedly till either freeze or desktop refreshes no pop-up menu.Show menu immediately, slight chance of this happening.... -
Problem with right click on desktop
in Windows 10 CustomizationProblem with right click on desktop: I have an issues on Windows 10 Desktop where when I right click , I get the circle for minutes, and then nothing happens. When I click on a file on desktop it works fine but it only hangs when I hit an empty space in the desktop and I can't figure out the reason. Anyone ever... -
mouse freeze right away after clicking on any software for a second !
in Windows 10 BSOD Crashes and Debuggingmouse freeze right away after clicking on any software for a second !: hi i just bought acer predator helios 300 ,and just out of box i noticed an issue which is once i click on any software or icon , basically anything that need to be double click to open not link or inside an application or while working normally inside any software the mouse... -
My desktop freezes after I right click. Help please!
in Windows 10 Ask InsiderMy desktop freezes after I right click. Help please!: So today I restored my pc to its factory settings and my pc has since been acting really weird. When I right click on my desktop, everything freezes. But here’s the weird thing I can still use the taskbar, for example on my taskbar I got google, and I’m able to open up google... -
When right clicking on desktop, the desktop freezes.
in Windows 10 CustomizationWhen right clicking on desktop, the desktop freezes.: Hi, i'm having a problem with my MSI Laptop, where I right click the desktop, then it will turn my cursor into the blue circle and try to boot up the screen the gives you all those settings. Then it will take around 2 minutes for that to actually show, but when I click it... -
How to fix this Right Click Desktop freezing problem?
in Windows 10 Performance & MaintenanceHow to fix this Right Click Desktop freezing problem?: Right clicking on desktop will promt a .2 freeze before the context menu will show, If I have a running apps it will be affected also, just by right clicking on a desktop. Now I figured it out that if the GEForce experience is active, desktop right click freeze will not...
