Windows 10: G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed
Discus and support G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed in Windows 10 Gaming to solve the problem; I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not... Discussion in 'Windows 10 Gaming' started by Taimur Ansari, Oct 24, 2024.
G Pro X Wireless plays mute/unmute sound when audio starts or volume is changed - Similar Threads - Pro Wireless plays
in Windows 10 Software and AppsG Pro X Wireless plays mute/unmute sound when audio starts or volume is changed: I'm having this issue since updating to Windows 11 24H2, I've talked to Logitech support and they said since this is only happening on my PC and not others, its a Windows 11 update issue.Here is what they said: I understand your concern. I request you to contact Windows... -
Sound muted if changes volume while playing
in Windows 10 Drivers and HardwareSound muted if changes volume while playing: Hi everyone, I have a rather odd problem.My sounds seem to works fine, however if I change volume while sound is playing, the sound is muted. It happens every time doing so.My laptop is running windows 10 and sound is played through computer's internal speakers.Here are what... -
in Windows 10 GamingSound muted if changes volume while playing: Hi everyone, I have a rather odd problem.My sounds seem to works fine, however if I change volume while sound is playing, the sound is muted. It happens every time doing so.My laptop is running windows 10 and sound is played through computer's internal speakers.Here are what... -
in Windows 10 Software and AppsSound muted if changes volume while playing: Hi everyone, I have a rather odd problem.My sounds seem to works fine, however if I change volume while sound is playing, the sound is muted. It happens every time doing so.My laptop is running windows 10 and sound is played through computer's internal speakers.Here are what... -
Sound muting and unmuting automatically
in Windows 10 GamingSound muting and unmuting automatically: My new PC keeps muting the sound and unmuting it automatically. I have searched forums and websites, but none have the answer. How do I stop this from happening?... -
in Windows 10 Software and AppsSound muting and unmuting automatically: My new PC keeps muting the sound and unmuting it automatically. I have searched forums and websites, but none have the answer. How do I stop this from happening?... -
in Windows 10 BSOD Crashes and DebuggingSound muting and unmuting automatically: My new PC keeps muting the sound and unmuting it automatically. I have searched forums and websites, but none have the answer. How do I stop this from happening?... -
How to Mute or Unmute Sound Volume in Windows 10
in Windows 10 NewsHow to Mute or Unmute Sound Volume in Windows 10: In Windows 10, you can easily adjust the volume level of individual devices and apps, in some cases, you may just want to mute and unmute the volume as needed without affecting the set volume level. In this post, we will show you how to mute or unmute Sound Volume in Windows... -
Volume Mixer Shows Sound Muting and Unmuting
in Windows 10 Drivers and HardwareVolume Mixer Shows Sound Muting and Unmuting: As of recently I've been experiencing some sound problems. At first it showed my volume unmuting and muting very quickly when I wasn't doing anything. I did some troubleshooting and it told me that "opening audio enhancements might help", and gives me an option to open or to...
