Windows 10: Have problem running on battery since upgrade to 1703
Discus and support Have problem running on battery since upgrade to 1703 in Windows 10 Drivers and Hardware to solve the problem; You need to go back and look in detail. The first one is critical action and it can be set to shutdown or nothing or hibernate. Please look at each... Discussion in 'Windows 10 Drivers and Hardware' started by keesadad, Nov 7, 2017.
	Page 2 of 5
	Page 2 of 5
            Have problem running on battery since upgrade to 1703 - Similar Threads - problem running battery
            Having problem with batteryin Windows 10 GamingHaving problem with battery: Hi everyone, I’m having some trouble with my Dell laptop battery. Around 4-5 months ago, I had to replace the old battery because it wasn’t charging or even powering up the laptop. I had been using it with the charger plugged in all the time. When I took it to a repair shop,...
            Having problem with batteryin Windows 10 Software and AppsHaving problem with battery: Hi everyone, I’m having some trouble with my Dell laptop battery. Around 4-5 months ago, I had to replace the old battery because it wasn’t charging or even powering up the laptop. I had been using it with the charger plugged in all the time. When I took it to a repair shop,...
            Having some problems since upgrading to 10...in Windows 10 Ask InsiderHaving some problems since upgrading to 10...: I use my TV as a monitor. Resolution was way off since before I upgraded to 10, but circumvented it by scaling the text extra large. Now since upgrading, everything is too big. Text is blurry, icons too big, task bar goes below where I can see. I went to display settings...
            Cursor Problems since 1703. No rollback, No fixable updates, problem persistsin Windows 10 Drivers and HardwareCursor Problems since 1703. No rollback, No fixable updates, problem persists: Hello. Since the Fall Creator's update !703, the cursor has been acting very bad. First problems I noticed back in 1703 was that the cursor would hang or dissappear. Back then, rolling back was the only solution. Tried updating, reinstalling drivers, reinstalling computer,...
            Having a lot of problems with windows 10 1703in Windows 10 BSOD Crashes and DebuggingHaving a lot of problems with windows 10 1703: I just bought a new Asus laptop which ran gift box and I downloaded some apps like firefox and zip but when I tried to update, it had an error I tried retrying multiple times but nothing is working I tried almost every solution here that I can find but nothing worked. I ran...
            Windows 10 1703 upgrade won't runin Windows 10 Installation and UpgradeWindows 10 1703 upgrade won't run: This is an ASUS CM6870, i7 CPU, 16GB ram, wireless option, UEFI BIOS about 4 yrs old and came with W7 installed. I clean installed 1703, but after install it does not boot but instead locks up with a bluish screen (not BSOD) and non-movable mouse pointer. So I clean...
            Problems upgrading old laptop from 1607 to 1703in Windows 10 Installation and UpgradeProblems upgrading old laptop from 1607 to 1703: I'm having problems upgrading my old laptop, which was happily running version 1607, to version 1703. Any ideas what I should try next? When I say "old" laptop... it came with XP, but has run Windows 8, 8.1, 10 Preview, and versions of Windows 10 up to 1607. So far I've...
