Windows 10: Headphone volume smoothes in instead of having a constant volume. Auto detection of audio...
Discus and support Headphone volume smoothes in instead of having a constant volume. Auto detection of audio... in Windows 10 Gaming to solve the problem; Hi, I have been searching a lot to find a switch for a setting that enables or disables smoothing in of audio on headsets or in other words auto... Discussion in 'Windows 10 Gaming' started by Joakim Baardset, Jan 11, 2025.
  1. Headphone volume smoothes in instead of having a constant volume. Auto detection of audio...
    Hi, I have been searching a lot to find a switch for a setting that enables or disables smoothing in of audio on headsets or in other words auto detection of audio. We have this problem on several of our headsets. It seems like the headsets automatically detects audio and then smoothes it in and increases the volume instead of having a constant volume level. This makes it very hard to communicate over TRBOnet, where we talk over radio to colleagues in maritime enviroments. We use TRBOnet for short messages and for security for our employees that work at sea. Since the audio is never const
  2. Volume with headphones
    With headphones plugged in, my volume stays at a constant 37 even when attempting to increase the volume.
    How do I increase the volume?
    RaphaelLos, Jan 11, 2025
  3. headphones directional audio issue
    Hi
    Welcome to Microsoft community.
    It sounds like you've identified that your Razer Kraken headphones have suffered some physical damage that affects the directional audio, and you're looking for a way to make them usable by playing all audio through the working part of the headphones. Here are a few steps and suggestions you can try to achieve this:
    Step 1: Enable Mono Audio and Adjust Volume
    Since you mentioned that enabling mono audio makes the sounds incredibly quiet, you can try to increase the system volume and the application volume to compensate. Here’s how to do it:
    1. Enable Mono Audio:
      • Open Settings.
      • Go to Ease of Access > Audio.
      • Toggle on Turn on mono audio.
    2. Adjust System Volume:
      • Right-click the sound icon in the taskbar and select Open Volume mixer.
      • Ensure all volume sliders are set to maximum.
    3. Adjust Application Volume:
      • Open the application you are using (e.g., Fallout 4).
      • Go to the audio settings within the application and ensure the volume is set to maximum.
    Step 2: Check Realtek Audio Console Settings
    Since you have Realtek Audio Console, ensure it’s configured correctly:
    1. Open Realtek Audio Console:
      • Search for Realtek Audio Console in the Start menu and open it.
    2. Check Speaker Configuration:
      • Go to the Speakers tab.
      • Ensure that the Headphone Virtualization and Front left and right full-range speakers are configured correctly.
    3. Use Loudness Equalization:
      • Go to the Enhancements tab.
      • Enable Loudness Equalization to help balance out the audio levels.
    Step 3: Hardware Fix (Optional)
    If you're comfortable with a bit of DIY, you could try to repair the headphone cable. This involves:
    1. Cutting the damaged part of the cable.
    2. Soldering the wires back together or using a new 3.5mm jack.
    3. Covering the exposed wires with electrical tape or heat shrink tubing.
    There are many tutorials online that can guide you through this process. However, this requires some basic knowledge of electronics and soldering.
    If none of these solutions work, it might be time to consider investing in a new pair of headphones.
    Let me know if you need further assistance.
    Best regards
    Derrick Qian | Microsoft Community Support Specialist
    Derrick.Q - MSFT, Jan 11, 2025
  4. Headphone volume smoothes in instead of having a constant volume. Auto detection of audio...
    Headphone and Speaker volume Windows 10
    How to separate the volume of speaker and headphone phone volume. I am using Realtek High Definition Audio. My headphone is not in the sound list.
    Microsoft account user, Jan 11, 2025
  1. Headphone volume smoothes in instead of having a constant volume. Auto detection of audio... - Similar Threads - Headphone volume smoothes
  2. Headphone volume smoothes in instead of having a constant volume. Auto detection of audio...
    Headphone volume smoothes in instead of having a constant volume. Auto detection of audio...: Hi, I have been searching a lot to find a switch for a setting that enables or disables smoothing in of audio on headsets or in other words auto detection of audio. We have this problem on several of our headsets. It seems like the headsets automatically detects audio and...
  3. Audio is constantly at the same volume
    Audio is constantly at the same volume: I believe my audio driver is broken, but every single thing I see including the manufacturer website says the driver itself is up to date and is perfectly fine. Unless this is a headphone issue itself?It is a Realtek driver, not sure what these Headphones are, I believe...
  4. Audio is constantly at the same volume
    Audio is constantly at the same volume: I believe my audio driver is broken, but every single thing I see including the manufacturer website says the driver itself is up to date and is perfectly fine. Unless this is a headphone issue itself?...
  5. Audio is constantly at the same volume
  6. Headphones Volume no longer controlled via their external volume slider and instead stuck...
    Headphones Volume no longer controlled via their external volume slider and instead stuck...: I dont know how well to describe this, Ive had this problem since last night. Anyway all of sudden my external and wired headphones Turtle Beach Earforce X12 which I have used perfectly fine they are also pretty newish suddenly stopped working properly. Now sound DOES come...
  7. Headphones Volume no longer controlled via their external volume slider and instead stuck...
  8. Headphones Volume no longer controlled via their external volume slider and instead stuck...
  9. Headphones change volume/audio mode by itself
    Headphones change volume/audio mode by itself: Hi,I have a problem with Microsoft Modern Wireless Headset.If there is no sound being played currently no music/video/system sound they keep changing the volume/quality of audio by themselves.In one instance the quality is nice, and the volume spinner on the headphones is...
  10. Volume with headphones
    Volume with headphones: With headphones plugged in, my volume stays at a constant 37 even when attempting to increase the volume. How do I increase the volume? https://answers.microsoft.com/en-us/windows/forum/all/volume-with-headphones/c92bb397-4b5f-4e0e-935a-76eac624fa3f
