Windows 10: hello im having a problem with my wifi speed i need help ASAP
Discus and support hello im having a problem with my wifi speed i need help ASAP in Windows 10 Network and Sharing to solve the problem; So I just upgraded my pc from xp to 10 pro runs fine but i ran into a issue where i have exellent signal strength but 320kb/per sec when i download... Discussion in 'Windows 10 Network and Sharing' started by LINI _, May 26, 2024.
hello im having a problem with my wifi speed i need help ASAP - Similar Threads - hello having problem
Hello, I need help ASAP.
in Windows 10 GamingHello, I need help ASAP.: I installed a windows update and a few minutes after the install I blue screened, my pc was lagging and it blue screened and it showed the Critical prosses died log or reason. I don't know a lot about pcs and all that and I've looked up tutorials trying to fix it and looked... -
in Windows 10 Software and AppsHello, I need help ASAP.: I installed a windows update and a few minutes after the install I blue screened, my pc was lagging and it blue screened and it showed the Critical prosses died log or reason. I don't know a lot about pcs and all that and I've looked up tutorials trying to fix it and looked... -
in Windows 10 Installation and UpgradeHello, I need help ASAP.: I installed a windows update and a few minutes after the install I blue screened, my pc was lagging and it blue screened and it showed the Critical prosses died log or reason. I don't know a lot about pcs and all that and I've looked up tutorials trying to fix it and looked... -
in Windows 10 Gaminghello im having a problem with my wifi speed i need help ASAP: So I just upgraded my pc from xp to 10 pro runs fine but i ran into a issue where i have exellent signal strength but 320kb/per sec when i download something my network adapter name is Ralink rt61 turbo wireless card 2.4ghz when i go to https://www.speedtest.net it says... -
in Windows 10 Software and Appshello im having a problem with my wifi speed i need help ASAP: So I just upgraded my pc from xp to 10 pro runs fine but i ran into a issue where i have exellent signal strength but 320kb/per sec when i download something my network adapter name is Ralink rt61 turbo wireless card 2.4ghz when i go to https://www.speedtest.net it says... -
I need help asap
in Windows 10 BSOD Crashes and DebuggingI need help asap: I deleted something from registry editor which is connected to the trojan virus that came from the cracked app that ive download, since then it started to act like crazy everytime i restart it i need to end task the windows explorer so i can go to my previous windows. Can... -
Need help with wifi speed
in Windows 10 Ask InsiderNeed help with wifi speed: Hi all My phone and laptop are connected to same wifi But from yesterday only in my laptop browsing and downloading become too slow. I tried virus scan in boot. Ipconfig reset nothing works Sometimes suddenly speed will come for a min and goes down even opening google.com... -
I need help ASAP
in Windows 10 Ask InsiderI need help ASAP: Hi there stranger, Recently, my laptop has been running extremely slowly. To be honest I don’t know where to pist this and I’ve tried everything that the threads on the official lenovo website have given me which result in a temporary fix. This is my problem, I boot up my... -
I need help ASAP
in Windows 10 SupportI need help ASAP: Ok so I wanted more space on my computer and me not knowing what to do I went to file Explorer, clicked local disk and I got about like 10 gist back of data but when I did that and emptied my recycling bin I could open nothing up. When I try to open up Microsoft edge it...
