Windows 10: HELP FAST!! SHORTCUT PROBLEM
Discus and support HELP FAST!! SHORTCUT PROBLEM in Windows 10 Ask Insider to solve the problem; Hello!! I need tech person to help me!!! Okay, so I had to format my SD card (removable drive) and I copied all of my files, then I formatted. I tried... Discussion in 'Windows 10 Ask Insider' started by /u/ItzShemy, Jan 20, 2020.
  1. HELP FAST!! SHORTCUT PROBLEM
    Hello!! I need tech person to help me!!! Okay, so I had to format my SD card (removable drive) and I copied all of my files, then I formatted. I tried pasting all of my files, but it wouldn’t let me!!! Some error popped up saying it’s unable to, blah blah. So I did: “Paste Shortcut” and it turned all of my files into shortcuts! I tried pasting all of my other files onto other folders, and it’s no use! It would let me! Now, all of the files I’ve copied are gone, and I’m left with some dumb shortcut folder what was the remain of my folders!!!!
    I DID NOT HAVE A VIRUS/MALWARE TURN MY FILES INTO A SHORTCUT. I DID IT MYSELF HOW DO I TURN IT BACK?
    I’ve tried using the command prompt and attrib -h -r-s /s /d ., but it didn’t work!!!!! This is urgent! I’m completely useless without my files! I use these files every single day!!
    Main question: How do I convert my shortcut files back? The main ones are all deleted. I’m at a lost hope. Help!!!!!!
    submitted by /u/ItzShemy
    [link] [comments]
  2. terrace Win User
    Screensaver shortcut
    I did this"
    Search Results
    I would suggest you to try the following steps and check if that helps.
    • Go to the folder C:\Windows\System32 and sort by file type.
    • Look for the screensaver file type (.scr).
    • Find the file scrnsave.scr(you can choose any of the screensavers).
    • Right click and select send to>desktop (create shortcut). The shortcut on my attachment, but when i click on it my screen goes off and on and nothing else.HELP FAST!! SHORTCUT PROBLEM :)
    terrace, Jan 20, 2020
  3. Mussels Win User
    Shortcut problems
    ok ok... yes, i finally cave in and ask for help, rather than offering it *Stick Out Tongue HELP FAST!! SHORTCUT PROBLEM :p
    this ones probably simple for someone in the know, but i dont know where to look.
    Simple problem - the context menu (right clicking somewhere, such as on my desktop) wont let me create shortcuts. i click it, and nothing happens at all.
    All other items there work, just no shortcut wizard appears to let me enter the address/name for it.
    All pre-made shortcut files work just fine, so its merely a registry setting to do with creating them.
    Can anyone help out?
    (OS is vista x64 if it helps)
    Mussels, Jan 20, 2020
  4. alexp999 Win User
    Shortcut problems
    If you havent done them yet, I suggest doing the second one first and trying that before you add the first one.
    Hope it helps.
    alexp999, Jan 20, 2020
  1. HELP FAST!! SHORTCUT PROBLEM - Similar Threads - HELP FAST SHORTCUT
  2. Problem with shortcut
    Problem with shortcut: I uninstalled teams because it wouldn't let me log out and switch accounts and now when I try to open my outlook mail app I get an error message saying 'The item 'chrome_proxy.exe' that this shortcut refers to has been changed or moved, so this shortcut will no longer work'....
  3. Fast Startup Problem
    Fast Startup Problem: Why?? [ATTACH] Pls Help Me https://answers.microsoft.com/en-us/windows/forum/all/fast-startup-problem/83b79418-91e7-45d9-b01a-6477e9e54bd3
  4. Problems with fast startup.
    Problems with fast startup.: So, i have set the fast startup to ON. It works, but sometimes it just automaticallyturns off by itself. I don't do anything. When i turn it back on, it works fine. But after a while, it turns off again....
  5. Please help fast
    Please help fast: Windows 10 pro for 60 bucks is it original ? submitted by /u/Vamparics92 [link] [comments] https://www.reddit.com/r/Windows10/comments/gwjmji/please_help_fast/
  6. NEED HELP FAST
    NEED HELP FAST: Guys so i opened my laptop so i can play. I didnt do anything to it the last time i used it but now i encounter a problem. Everytime i rightlick a folder on desktop the spinning loading icon in the mouse appears and it doesnt stop. I already tried some video tutorials on yt...
  7. Problems with Creating Shortcuts FAST REPLY REALLY APPRECIATED!
    Problems with Creating Shortcuts FAST REPLY REALLY APPRECIATED!: I want to create desktop shortcuts for apps purchased from the Microsoft Store. But, I don't know how to do so. My normal solution for this would to open the file location, but this option isn't available for stuff purchased from MS Store. Help me. Thanks....
  8. Problem with shortcut
    Problem with shortcut: On windows 10.I tryed to back up my sd card photos and files. So I moved all faders as shortcut on desktop. The folders do not open. I get a sign saying to make sure that the disc is inserted properly or the network resource is available....
  9. help fast
    help fast: hi guys..iy donwload w10 and going istal and when checking for update stop ti 46%and dont move..nothing..cannit instal help.. https://answers.microsoft.com/en-us/windows/forum/all/help-fast/c88ed69f-c181-4615-acdb-8cfc4876278f
  10. Shortcut problem
    Shortcut problem: Upgraded from 8.1 to 10. Now all my "shortcut icons" all have what looks like a white notebook page covering most of them. Did not have the problem before going to Win 10 If I delete the program icon and then go and create another one, same thing happens. Icon is created with...
