Windows 10: help fixing Code 43 on a USB Sound Card works on another computer
Discus and support help fixing Code 43 on a USB Sound Card works on another computer in Windows 10 Drivers and Hardware to solve the problem; does anyone know how to fix this error on a USB Soundcard?Windows has stopped this device because it has reported problems. Code 43 A request for the... Discussion in 'Windows 10 Drivers and Hardware' started by plonk420, Sep 10, 2021.
help fixing Code 43 on a USB Sound Card works on another computer - Similar Threads - help fixing Code
GPU not working help code 43
in Windows 10 GamingGPU not working help code 43: my gpu is not working I have tried installing new drivers updating bios resetting bios reinstalled windows and uninstalled a million different drivers still the same thing gpu dose not show up in task manger either error code 43 in device manager My gpu is Nivida 1660itDevice... -
in Windows 10 Software and AppsGPU not working help code 43: my gpu is not working I have tried installing new drivers updating bios resetting bios reinstalled windows and uninstalled a million different drivers still the same thing gpu dose not show up in task manger either error code 43 in device manager My gpu is Nivida 1660itDevice... -
Help with a USB Thumb Drive Code 43
in Windows 10 Drivers and HardwareHelp with a USB Thumb Drive Code 43: I like others struggle with this.Samsung USB Thumb Drive Code 43 Error A request for the USB device descriptor failed.The SuperSpeed link to the USB device keeps going to an error state Compliance. If the device is removable, remove the device and then disable/enable from... -
USB code 43
in Windows 10 Drivers and HardwareUSB code 43: I have a usb blue yeti. I have been using it for the last 2 months everything has been find and now its not working as I have a USB code 43. I want to know how to fix it I have tried lots of things and nothing is working.... -
Error code 43 no fix works
in Windows 10 Drivers and HardwareError code 43 no fix works: i recently got error code 43 for my intel hd 4600 i dont have an external gpu and i have tried many fixes such as -reinstalling drivers -rolling back drivers -updating bios -reinstalling windows -going back a previous build none of them have worked for me my specs are Intel... -
Code 43, unknown USB.
in Windows 10 Drivers and HardwareCode 43, unknown USB.: Basically, I tried connecting my mouse, but when I tried it said this device wasn't recognized. I later tried checking my "Device Manager" which was of no help, because I uninstalled that device and re-installed it, and I also tried updating the driver, all these didn't work... -
Graphics card error code 43
in Windows 10 Graphic CardsGraphics card error code 43: Hello! I got the following driver error with my graphics card: "Windows has stopped this device because it has reported problems (code 43)" - causing horizontal white stripes on the screen and lowered resolution (800x600). I have an NVIDIA Geforce GTX Titan Black, and I've... -
When Connecting USB Card Reader it gets a code 43
in Windows 10 Drivers and HardwareWhen Connecting USB Card Reader it gets a code 43: When I connect my USB card reader which is a Q7S card reader. Which is this one here http://www.amazon.co.uk/Q7S-Memory-r.../dp/B00F759ZCM When I connect it ti my computer it stops working and in device manager it says Device Descriptor Request Failed and gets a code 43.... -
Card card showing up as Code 43
in Windows 10 Graphic CardsCard card showing up as Code 43: So everything was working fine up until yesterday, then my computer would just crash when I played a game. after the first time I still had both screens being detected, but the second time I lost my secondary monitor. I then went to get the latest drivers but the same...
