Windows 10: help!! my rear audio jack doesnt work
Discus and support help!! my rear audio jack doesnt work in Windows 10 Customization to solve the problem; in my front pair of jacks only audio works,but in the rear only the microphone works,i want to change my audio to the rear port.It shows me that no... Discussion in 'Windows 10 Customization' started by GrigorasAlexandru, May 6, 2020.
help!! my rear audio jack doesnt work - Similar Threads - help rear audio
Rear Audio Jack doesn't work
in Windows 10 Drivers and HardwareRear Audio Jack doesn't work: I bought new headphones, and for some reason when i connected them the rear green audio jack doesn't work. i have set it to "headphones" in the realtek audio console but it still doesn't seem to work. could anyone help me with this? i dont want to use a jack to usb adapter... -
Rear Port audio jack output right side not working
in Windows 10 BSOD Crashes and DebuggingRear Port audio jack output right side not working: Hi there, please give me the solution which is not from google search, this is second time happen, first time i had to reformat to make it working again both time also happening right after some windows monthly patch it happens. those basic uninstall and reinstall all had... -
No bass in rear audio jack
in Windows 10 Drivers and HardwareNo bass in rear audio jack: I'm using driver Realtek HDA 6.0.9132.1 but this has been going on with earlier drivers too for some time. My front jack is damaged and I have to find the perfect position for it to work so I wanted to use the rear jack but it had NO bass at all compared to the front jack. I... -
Rear audio jack not working
in Windows 10 Drivers and HardwareRear audio jack not working: I've tested different driver versions but it just doesn't work. It used to work sometime ago but not anymore. Update: it works with a different headphone but they have the exact same jack, and the one that doesnt work in the rear jack works in the front jack perfectly - - -... -
rear audio jack not working since update
in Windows 10 Installation and Upgraderear audio jack not working since update: The rear audio jack on my PC hasn't worked since a Windows update in early 2020. I've tried the recommended remedy of going to control panel, then 'sound' and checking on the volume which is fine, and nothing has worked. I'd greatly appreciate any help on this.... -
Rear Audio Jacks Access Headaches
in Windows 10 Drivers and HardwareRear Audio Jacks Access Headaches: In the past I have tried to sort out how to feed an old set of analog speakers or analog mic into the backside audio jacks several times without success. The speakers and mic work okay if I plug them into the front panel but not the back. In the previous runs I went... -
Headphones into rear audio jack?
in Windows 10 Drivers and HardwareHeadphones into rear audio jack?: Hello. The headphone input on the front of my PC is broken and I cannot use it anymore. No big deal I thought, I'll plug my headphones into the rear audio jack. Well... that ends up being a massive issue somehow. The back inputs seem to be coded differently, which makes the... -
Rear audio jack
in Windows 10 Drivers and HardwareRear audio jack: I was doing stuff on my computer, suddenly there was a loud pop and my sound is gone. I can still see my speakers, the troubleshooter comes back with literally nothing, my drivers are up to date and I restart my computer. The front audio jack does still work.... -
Rear Audio Jack Not Working at all
in Windows 10 Drivers and HardwareRear Audio Jack Not Working at all: Hello Everyone Last week I was changing my Graphiccard a few times to test another one and finally installed my old one back in. After I restarted my Computer all rear audio jacks as well as the front audio jacks stopped working. I can safely say, that it is not an issue...
