Windows 10: Help needed with Low CPU usage and Low FPS
Discus and support Help needed with Low CPU usage and Low FPS in Windows 10 Ask Insider to solve the problem; Since the last week i started getting low fps in ALL games all of a sudden and i tracked the culprit to be my CPU's low utilization which for some... Discussion in 'Windows 10 Ask Insider' started by /u/ibnkhan, May 20, 2020.
Help needed with Low CPU usage and Low FPS - Similar Threads - Help needed Low
low cpu and gpu usage causing fps drops
in Windows 10 Software and Appslow cpu and gpu usage causing fps drops: i have a hp omen gaming laptop with i7-10875h and rtx 3070. my laptop run pretty smooth while gaming and had my gpu usage was 98% and rare fps drop before but now both my cpu and gpu usage fluctuates a lot, and rarely hit above 70%. i have tried a lot of things but no... -
Sudden low fps and cpu usage in all games
in Windows 10 GamingSudden low fps and cpu usage in all games: A while ago I tried playing bg3 as always but I got sudden low fps drops that ive never had.Same with the other games, such as house flipper,ac etc.The cpu usage while running these games is around 10-25% and I have no other background apps that could effect that.I checked my... -
in Windows 10 Software and AppsSudden low fps and cpu usage in all games: A while ago I tried playing bg3 as always but I got sudden low fps drops that ive never had.Same with the other games, such as house flipper,ac etc.The cpu usage while running these games is around 10-25% and I have no other background apps that could effect that.I checked my... -
CPU usage Low
in Windows 10 GamingCPU usage Low: My laptop suddenly so laggy, when I check out the task manager I realized the CPU usage is so low, what should I do? I already tried to edit in power plan but it didn't work https://answers.microsoft.com/en-us/windows/forum/all/cpu-usage-low/04f852c0-a5b4-46e8-8a72-d49b37b8a220 -
CPU usage Low
in Windows 10 Software and AppsCPU usage Low: My laptop suddenly so laggy, when I check out the task manager I realized the CPU usage is so low, what should I do? I already tried to edit in power plan but it didn't work https://answers.microsoft.com/en-us/windows/forum/all/cpu-usage-low/04f852c0-a5b4-46e8-8a72-d49b37b8a220 -
low cpu usage and fps drop during games
in Windows 10 Gaminglow cpu usage and fps drop during games: First of all if you can answer my question in Turkish I will be happy. Yesterday I upgraded my GPU and bought new m.2 SSD. after that I installed Win 11. Win 11 automaticly installed AMD software that I never use. Because my gpu is nvidia and I am using that. After that I... -
in Windows 10 Software and Appslow cpu usage and fps drop during games: First of all if you can answer my question in Turkish I will be happy. Yesterday I upgraded my GPU and bought new m.2 SSD. after that I installed Win 11. Win 11 automaticly installed AMD software that I never use. Because my gpu is nvidia and I am using that. After that I... -
Low FPS/CPU usage?
in Windows 10 Ask InsiderLow FPS/CPU usage?: Low FPS? Hey there! (I'm not sure if this is the right subreddit) I noticed that when playing games such as Valorant and League of Legends, my frame rates in game, which were previously 150, are now 60. In addition, while running these games, my computer is really slow and... -
Low FPS Help
in Windows 10 GamingLow FPS Help: Hello, Recently I've had a problem with my PC. Whenever I launch a game, performance is fine, but continually worsens. For example, in Skyrim SE, I start at a stable 60 FPS and over time it worsens to 15 FPS. I tried uninstalling drivers, using OEM drivers and even...
