Windows 10: [HELP] No Audio Output Device is installed.
Discus and support [HELP] No Audio Output Device is installed. in Windows 10 Drivers and Hardware to solve the problem; I'm experiencing an issue that says I don't have an audio device installed. I couldn't listen to anything on YouTube, Netflix, or anything for that... Discussion in 'Windows 10 Drivers and Hardware' started by Amazin_Microsoft, Aug 5, 2021.
  1. [HELP] No Audio Output Device is installed.
    I'm experiencing an issue that says I don't have an audio device installed. I couldn't listen to anything on YouTube, Netflix, or anything for that matter. I resetted the device twice and reinstalled Windows. I'm using a Kano PC powered by Windows 10 Pro. I want to get this issue resolved as soon as possible because not having sound is a big issue.
  2. No Audio Output Device is Installed
    You will need to select Windows 8 from the drop down list while installing the driver in compatibility mode.
    I would suggest you to try setting the speaker as default audio output by following the steps below and check if it helps.
    1. Right click on the sound icon on the right bottom corner of the taskbar.
    2. Select "playback devices".
    3. If "speaker" is not set as the default device, highlight it and click "set as default".
    5. Save the changes.
    Let us know the result.
    Wungraileng Vashi, Aug 5, 2021
  3. No audio output device is installed
    Hi Oscar,
    I'm Charles, an Independent advisor trying to help.
    Please, check the instructions and suggestions in this article, it is a website managed by a Windows MVP, so it is reliable information.
    https://www.thewindowsclub.com/no-audio-output-...
    I hope the steps work for you
    Attentive to your comments
    Have a happy day
    Best Regards,
    Charles.
    CharlesJones32, Aug 5, 2021
  4. [HELP] No Audio Output Device is installed.
    You can also try this possible solution to your Issue
    Fix "No Audio Output Device Is Installed" Error with Device Mannager
    Device Manager is another troubleshooter which could help to fix many common computer issues, including "no audio output device is installed" error on Windows 10.
    Step 1. Open the search box, type devmgmt.mcs in the Run dialog to open Device Manager.
    Step 2. Scroll down to find the catagory "Sound, video and game controllers", expand it to locate your audio device and select it.
    Note: If you can not see the "Sound, video and game controllers" catagory, follow the steps below to find it.
    • Select "Action" on the top of the panel. (If there is no "Action" tab, click on the blank place and then click on "Action")
    • Select "Add Legacy hardware".
    Click Next on the popping up Add Hardware Wizard window.
    • Choose "Search for and install hardware automatically" and then hit "Next". (If the Wizard message reads "the wizard did not find any new hardware on your computer", click Next)
    Scroll down to locate the "Sound, video and game controllers" option.
    • Select it and then click Next.
    • Choose your exact sound card and then click Next.
    Click Next to install the audio driver and then click Finish.
    Step 3. Right-click on the audio device. Select Enable.
    Step 4. Now check whether the audio issue is solved. If persists, choose Uninstall to remove the audio driver.
    Step 5. Reboot your computer to save the changes and Windows will load you the audio driver automatically.
    Source:
    https://www.drivethelife.com/windows-10/fix-no-...
    Wilfredo_Soto, Aug 5, 2021
  1. [HELP] No Audio Output Device is installed. - Similar Threads - HELP Audio Output
  2. No audio output device is installed
    No audio output device is installed: Hi,Laptop: Medion P6645 / Windows 10I turned my laptop on this morning and there is a red cross next to my speaker icon.It says speaker setup unknown and in output and input devices there are no options to select.In device manager sound is hidden, unhiding it I then...
  3. Need help with "No Audio Output Device is installed"
    Need help with "No Audio Output Device is installed": So I was on my pc to check to start class then i see that I can't put my volume up. I thought it could just be an update error so I checked the updates. (which last checked was like 10 mins b4 i got back on, and the update would almost never work) when I tried to do the...
  4. "No audio output device is installed" Help?
    "No audio output device is installed" Help?: I have recently upgraded my PC to Windows 10 and just this morning my audio is nonexistent with the error "No audio output device is installed". My audio didn't have any problems after upgrading till I put it to sleep for the night and found it broken the next day. I have...
  5. no audio output device is installed notification HELP
    no audio output device is installed notification HELP: Yesterday I had audio and today no audio https://answers.microsoft.com/en-us/windows/forum/all/no-audio-output-device-is-installed-notification/a16dc5ab-c586-4346-acf0-9ff7245d933e
  6. No Audio Output Device is installed PLEASE HELP ;_;
    No Audio Output Device is installed PLEASE HELP ;_;: I've been working with computers for a while but this has me stumped. Motherboard is a FM2A58M-VG3+ R2.0 Not only do I not have any sound, I also have 9 unknown devices in the AudioBus which I have attempted to update to no avail, using windows update, various update...
  7. no audio output device is installed help
    no audio output device is installed help: My pc says no audio output device is installed help https://answers.microsoft.com/en-us/windows/forum/all/no-audio-output-device-is-installed-help/5f42359e-d92a-4385-9fe1-32fd410cfaef
  8. No audio output device is installed
    No audio output device is installed: I bought a new headset, plugged it in, sound works great. Of course, when ever i'm using a computer something has to fail. And this something was the microphone. Microphone works fine on other devices. It appeared that the mic was not plugged in(yes, I did plug it in). After...
  9. No Audio Output Device is installed
    No Audio Output Device is installed: Hi, Yesterday my sound was working fine, I walked away from my notebook for 15 minutes and came back and the sound icon had a red X against it. The error message when I hover over it is 'No Audio Output Device is installed'. In Device Manager the error message for...
  10. No Audio Output Device is installed
    No Audio Output Device is installed: Hi. Long time ago, I play with upgrading HDD to SSD, GRUB and some other stuff and I failed and messed my computer up. Now my desktop is still using HDD and does not produce any sound. I tried to fix this problem by Googling "No Audio output device is installed" but I...
