Windows 10: [help] No sound when running application as admin
Discus and support [help] No sound when running application as admin in Windows 10 Ask Insider to solve the problem; When I run an application as an admin you will usually here that sound after u right click the application and press run as administrator. My pc is not... Discussion in 'Windows 10 Ask Insider' started by /u/Kyle1641, May 2, 2020.
[help] No sound when running application as admin - Similar Threads - help sound running
need help with fixing the run as admin
in Windows 10 Gamingneed help with fixing the run as admin: I was messing around in gpedit and in local policies, the most bottom folder and the most bottom selection in the bottom folder, i pressed enable and now when i try to run anything with admin user and password it wont show the option to insert admin user and password and... -
in Windows 10 Software and Appsneed help with fixing the run as admin: I was messing around in gpedit and in local policies, the most bottom folder and the most bottom selection in the bottom folder, i pressed enable and now when i try to run anything with admin user and password it wont show the option to insert admin user and password and... -
Help! DRIVER_POWER_STATE_FAILURE BSOD for ntoskrnl.exe when running graphics applications...
in Windows 10 GamingHelp! DRIVER_POWER_STATE_FAILURE BSOD for ntoskrnl.exe when running graphics applications...: Hi I'm pretty sure that this is not a hardware issue. I have a Dell Precision 5530 still under warranty and Dell has verified that all the hardware is fine. But recently since May every time I have any graphics-heavy app open in the background and/or idle and I return from... -
in Windows 10 Software and AppsHelp! DRIVER_POWER_STATE_FAILURE BSOD for ntoskrnl.exe when running graphics applications...: Hi I'm pretty sure that this is not a hardware issue. I have a Dell Precision 5530 still under warranty and Dell has verified that all the hardware is fine. But recently since May every time I have any graphics-heavy app open in the background and/or idle and I return from... -
Help with running/downloading applications
in Windows 10 Ask InsiderHelp with running/downloading applications: So I just switched from my mom's Mac Mini computer to a fancy gaming Windows 10 computer of my own and I'm having trouble with running certain applications? For example I'm trying to download the rgb control software for my Tecware Phantom 87 key keyboard, it saves it as a... -
Stopping an application from running on admin
in AntiVirus, Firewalls and System SecurityStopping an application from running on admin: When I go to properties, shortcuts, and then advanced I uncheck the box and then click done. But after I click done I check to see if it worked and the box ticked itself automatically. Please help.... -
No sound output when running an application
in Windows 10 Drivers and HardwareNo sound output when running an application: Ever since my PC went over to working with Windows 10, I have had ongoing trouble running an application known as 'Spin it Again', https://acoustica.com/products/spin-it-again. I am not getting any audio output when running this. I do get audio with other applications, the... -
application run as admin
in Windows 10 Customizationapplication run as admin: Hi Team, i have windows10 pro 64 bit operation system and part of domain account. i facing below mentioned issues while open the application. 1. i have installed that application using local administrator profile 2. but when my user login with domain user profile and... -
All applications only run when clicking "Run as Admin"
in Windows 10 Software and AppsAll applications only run when clicking "Run as Admin": I got this issue a few days ago, after my dad accidentally shared my entire hard drive. Now, whatever application I run, I have to right click it, and run as an admin, or I get an error or the application doesn't run at all. The thing is, I'm the only admin on my computer....
