Windows 10: [Help] Sudden freezing and Event Viewer tons of problem
Discus and support [Help] Sudden freezing and Event Viewer tons of problem in Windows 10 BSOD Crashes and Debugging to solve the problem; Hello, i need some help to fix my laptop The problem start when suddenly my laptop freezing and i can't even open the task manager (ctrl+alt+del)... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Sapta Candra Dharma, Feb 9, 2019.
[Help] Sudden freezing and Event Viewer tons of problem - Similar Threads - Help Sudden freezing
Event Viewer Problems...
in Windows 10 BSOD Crashes and DebuggingEvent Viewer Problems...: I just went into my Event Viewer and noticed a slew of problems that has been happening for a while now. The main issue I've seen is "Distributed COM" errors/warnings. Heres the details as copied from my Event Viewer... -
Event viewer problem
in Windows 10 BSOD Crashes and DebuggingEvent viewer problem: I ran into a problem yesterday in event veawer if anyone could help me to fix it? https://answers.microsoft.com/en-us/windows/forum/all/event-viewer-problem/8ef3a589-909e-4f1f-a0a5-f49fba67c91e -
in Windows 10 Software and AppsEvent viewer problem: I ran into a problem yesterday in event veawer if anyone could help me to fix it? https://answers.microsoft.com/en-us/windows/forum/all/event-viewer-problem/8ef3a589-909e-4f1f-a0a5-f49fba67c91e -
Event Viewer Freezes
in Windows 10 BSOD Crashes and DebuggingEvent Viewer Freezes: Hello, I am using Windows 10 21H1. As far as I know this has happened to every version since 1903 which I was forced to upgrade from several weeks ago.I have a fresh install and all of my drivers are up to date.If I open the event viewer mmc, open and event and then close the... -
Event Viewer freezes
in Windows 10 BSOD Crashes and DebuggingEvent Viewer freezes: Hi, After upgrade from 1909 to 2004 and after displaying properties of a single event the event viewer freezes. I can use the up/down arrows while an event property is open but as soon as I close the event property there is no way to select anything within the event viewer... -
Tons of entries involving "edgecastcdn.net" in Event Viewer, what is it?
in Windows 10 Network and SharingTons of entries involving "edgecastcdn.net" in Event Viewer, what is it?: In my Event Viewer, there is a huge number of entries that say "Name resolution for the name x.y.edgecastcdn.net timed out after none of the configured DNS servers responded." (where x is usually a cs followed by a number, and y is either "wac" or "wpc"). There is an entry... -
Tons of event viewer errors, warnings and criticals!
in Windows 10 Performance & MaintenanceTons of event viewer errors, warnings and criticals!: Hey guys I'm new to Windows 10 and Event viewer and I am unable to understand what it is saying, this used to happen to my Windows 8.1 and I thought that after upgrading to 10 this might stop but here it is again! Please take a look at the pictures attached for better... -
TONS of errors in event viewer
in Windows 10 Performance & MaintenanceTONS of errors in event viewer: I just clean installed my windows, and have not made any changes as to what would cause these errors.... but in event viewer, since install on the 29th, i have 800 errors and warnings. ive noticed on my other PC that i just installed 10 on yesterday, it too has 300 errors and... -
Tons of comruntime error 10031 in event viewer
in Windows 10 SupportTons of comruntime error 10031 in event viewer: Ever since I did the latest updates on Tuesday...I've been getting tons of comruntime error 10031. It happens when the computer is idle and I noticed the hard drive light is steady on..I did some googling, but didn't find much...mostly on a server computer which I don't have....
