Windows 10: help with problem driver
Discus and support help with problem driver in Windows 10 Drivers and Hardware to solve the problem; 260ci WIA Driver (USB) stop working. Help... Discussion in 'Windows 10 Drivers and Hardware' started by RaymondChermace, Jan 13, 2019.
  1. help with problem driver
  2. Shuyin03 Win User
    New here and seeking for help: problems with graphic card
    Thanks very much lilhasselhoffer. I'll start doing what you suggested step by step.
    One question thou: you suggested me to Download the latest driver package from Nvidea. However, the link you posted is for the newly released GeForce GTX 760? Am I supposed to download the drivers for that card?
    Sorry for my questions. As I said, I'm not an expert at all.
    Shuyin03, Jan 13, 2019
  3. help to remote connect
    not sure how to use both programs u 2 suggested, i need more helpful steps thanks
    Corduroy_Jr, Jan 13, 2019
  4. dmccoy Win User
    Nvidia driver problem with 940 MX on Windows 10 x64
    I would only go back to the driver from the computers manufacturers if you experience any issues with the latest drivers from devie manufacturers.
    If everything is still working well with the clean boot then you can start troubleshooting as follows to start:
    How to determine what is causing the problem after you do a clean boot
    1. Log on to the computer by using an account that has administrator rights.
    2. From Start, search for msconfig. (In Windows 10, use the Search box from the Start menu. In Windows 8 or 8.1, swipe in from the right edge of the screen, and then tap Search. Or, if you are using a mouse, point to the lower-right corner of the screen, and then click Search.)
    3. Select msconfig or System Configuration from the search results.
    4. Tap or click the Services tab, and then tap or click to select the Hide all Microsoft services check box.
    5. Tap or click to select the upper half of the check boxes in the Service list.
    6. Tap or click OK, and then tap or click Restart.
    7. After the computer finishes restarting, determine whether the problem still occurs.
    • If the problem still occurs, repeat steps 1 through 6, but clear the lower half of the check boxes in the Service list that you originally selected.
    • If the problem does not occur, repeat steps 1 through 6, and select only the upper half of the remaining check boxes that are cleared in the Service list. Repeat these steps until you have selected all the check boxes.
    • If you still experience the problem when only one service is selected in the Service list, this means that the selected service causes the problem, and you should go to step 11. If no service causes the problem, go to step 8.
    8. Repeat steps 1 and 3 in this section.
    9. Tap or click the Startup tab, and then tap or click to select the upper half of the check boxes in the Startup Item list.
    10. Click OK, and then click Restart.
    • If the problem still occurs, repeat steps 8 and 9, but clear the lower half of the checked boxes in the Startup Item list that you originally selected.
    • If the problem does not occur, repeat steps 8 and 9, and select only the upper half of the remaining check boxes that are cleared in the Startup Item list. Repeat these steps until you have selected all the check boxes.
    • If you still experience the problem after only one Startup Item is selected in the Startup Item list, this means that the selected Startup Item causes the problem, and you should go to step 11. If no Startup Item causes this problem, a Microsoft service probably causes the problem. To determine which Microsoft service may be causing the problem, repeat steps 1 through 7 without selecting the Hide all Microsoft services check box in each step.
    11. After you determine the startup item or the service that causes the problem, contact the program manufacturer to determine whether the problem can be resolved. Or, run the System Configuration utility, and then tap or click to clear the check box for the problem item.
    From <https://support.microsoft.com/en-us/help/929135/how-to-perform-a-clean-boot-in-windows>
    dmccoy, Jan 13, 2019
  1. help with problem driver - Similar Threads - help problem driver
  2. ONN Mouse Driver problems, please help.
    ONN Mouse Driver problems, please help.: I have replaced a plug and play ONN mouse and Windows downloaded a generic driver. I am having trouble with the mouse. I used another mouse before this one thinking the problem is the mouse but I am thinking now that iw is something to do with the driver or some update that...
  3. ONN Mouse Driver problems, please help.
  4. ONN Mouse Driver problems, please help.
  5. Network drivers problem , please help !!
    Network drivers problem , please help !!: Currently I'm using windows 10 pro on my hp x360 pavilion laptop , yesterday I found that my wifi was not working....I checked the driverIt was showing that wifi adapter aren't working .It's saying to reconnect hardware with computer.......I did everything , updation is...
  6. Wifi driver has problem stuck please help!
    Wifi driver has problem stuck please help!: [ATTACH] submitted by /u/cheesyfriedrice [link] [comments] https://www.reddit.com/r/Windows10/comments/jt7pzz/wifi_driver_has_problem_stuck_please_help/
  7. Driver Help
    Driver Help: So, I need to use the noise suppression for my mic and I'm installing the Realtek audio drivers to do that. But I have tried 2 different times and the enhancement tab still isn't showing, it is not in device manager either. If there is any other way I could use the noise...
  8. Help - Stubborn Wireless Driver Problem.
    Help - Stubborn Wireless Driver Problem.: The problem started about a couple weeks ago and it evolved over time. Problem setup: Surfing the internet over my Lenovo Ideapad 520 Laptop via WiFi. Initially the problem spawned randomly, surfing the internet then the connection drops and the Chrome Dinosaur appears,...
  9. (Problem With Drivers / Devices) Please Help Me ~ October ~
    (Problem With Drivers / Devices) Please Help Me ~ October ~: [img] As you can tell from looking at this; there are Outdated Devices / Drivers. *Shock Problem that I have is that I apparently MUST purchase the Software in order to update them. So, can someone please help me? Because these 3 Drivers / Devices are causing BSOD no...
  10. Wifi Driver and Taskbar problems, I need help
    Wifi Driver and Taskbar problems, I need help: Ok let me start by saying I don't know much about this stuff so bear with me plz. I have two problems: 1. Every time I restart or startup my computer the wifi driver does not work so I have to uninstall it then reinstall it. My computer is a Lenovo y510p the driver that I...
