Windows 10: Hi I have a couple of problem and I need your help and acknowlage to get over it thank you...
Discus and support Hi I have a couple of problem and I need your help and acknowlage to get over it thank you... in Windows 10 Software and Apps to solve the problem; Firs one that a few press of my keyboard does not work like windows press and z press even the ctrl press and shift and Caps Lock press and knowing... Discussion in 'Windows 10 Software and Apps' started by Dalia-7, Jan 26, 2025.
  1. Dalia-7 Win User
    Firs one that a few press of my keyboard does not work like windows press and z press even the ctrl press and shift and Caps Lock press and knowing they are in the left side i had this problems so long time ago and still could not solve it yet. The other problem which more importent for me the Bluetooth Le device connection: My lap type is acer Spin 3 icore 5 and recently i have updated this> 2025-01 Cumulative Update for Windows 11 Version 24H2 for x64-based Systems. I have an ear hearing aid oticon intent 1 i m trying to connect it to my laptop but beside i have updated my lap stil show
  2. help to remote connect
    not sure how to use both programs u 2 suggested, i need more helpful steps thanks
    Corduroy_Jr, Jan 26, 2025
  3. Hi, XPS M1710 display help thanks
    Hi G Blackf,
    We appreciate you for being a part of Windows 10.
    As you have mentioned in the post, I understand that the highest display resolution settings you can set in your computer is 1600*200
    after upgrading to Windows 10.
    Are you able to set the display resolution higher than 1600*1200 prior to the Windows 10 upgrade?
    I suggest you to follow the below steps and check if it helps.
    Step 1:
    Please follow the steps to change the Resolution settings.
    • Open the Start menu, type Display settings
      in the search bar and click on Display settings.
    • Change the size of text, apps and other items to
      recommended level (100%).
    • Now click on Advanced display settings on the bottom of the Customize your display page.
    • Click on Resolution drop down menu and select the
      recommended level.
    Step 2:
    I suggest you to update the Display adapter drivers in Windows 10 and check if it fix the screen resolution.
    Refer to the following article to update all the drivers available in Windows 10.
    How to: Install and Update drivers in
    Windows 10
    I hope the above information helps. Kindly let us know if you need any further assistance with Windows. We are glad
    to assist you.
    Kiran Kishore, Jan 26, 2025
  4. dalchina Win User
    Windows 10 1709 System Restore problems...
    That seems to be an attempt at Option 2 in the tutorial, which requires you to
    a. Boot to a command prompt (Did you?)
    b. You then seem to be mixing steps 3,4 and 5, thus your command is incorrect.
    I suggest Option 1 is easier.
    If you still have problems, please repost listing each specific step and saying which option from the tutorial you are using. Thanks.
    dalchina, Jan 26, 2025
  1. Hi I have a couple of problem and I need your help and acknowlage to get over it thank you... - Similar Threads - couple problem need
  2. Hi I have a couple of problem and I need your help and acknowlage to get over it thank you...
    Hi I have a couple of problem and I need your help and acknowlage to get over it thank you...: Firs one that a few press of my keyboard does not work like windows press and z press even the ctrl press and shift and Caps Lock press and knowing they are in the left side i had this problems so long time ago and still could not solve it yet. The other problem which more...
  3. I need help with BSOD please. Thank you in advance
    I need help with BSOD please. Thank you in advance: Minidump Info5: kd> !analyze -v******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************SYSTEM_SERVICE_EXCEPTION 3bAn exception happened while...
  4. I need help with BSOD please. Thank you in advance
  5. hi i need help i keep getting the 0x800700e1code but it shows that there is no problem. I...
    hi i need help i keep getting the 0x800700e1code but it shows that there is no problem. I...: hi i need help i keep getting the 0x800700e1code but it shows that there is no problem. I allready tried fllowing tutorials and i dont know what to do...
  6. Hi, friends, can you help with this problem? i hope to get a good answer . thanks
    in Windows Hello & Lockscreen
    Hi, friends, can you help with this problem? i hope to get a good answer . thanks: Hi, friends, can you help with this problem? i hope to get a good answer . thanks https://answers.microsoft.com/en-us/windows/forum/all/hi-friends-can-you-help-with-this-problem-i-hope/27009330-afcd-4b6a-bda0-b263775ca36c
  7. Hi, friends, can you help with this problem? i hope to get a good answer . thanks
  8. Hi, friends, can you help with this problem? i hope to get a good answer . thanks
  9. Hi i need your help.
    Hi i need your help.: hi i can't believe im doing this but needs be, over the last year ive worked my ass off so my 15 yr old son could get a top system pc together , hhe likes streaming and making videos, i sold components from my own pc for enough for his build, heres the this ive just finished...
  10. Hi i need your help.
