Windows 10: Hording Useless PC Parts
Discus and support Hording Useless PC Parts in Windows 10 Drivers and Hardware to solve the problem; I was in high tech work since 1960, analog back then, and digital since before 1968. Started building or buying PCs from then mid-1970’s and continued... Discussion in 'Windows 10 Drivers and Hardware' started by dustymars, Mar 22, 2018.
Page 1 of 3
Page 1 of 3
Hording Useless PC Parts - Similar Threads - Hording Useless Parts
New PC Parts/Motherboard
in Windows 10 GamingNew PC Parts/Motherboard: Hi, im upgrading my entire pc, except for the storage and i want to know, can i reinstall windows, do i need to buy another licence, and how does that actually work?Since im switching from intel to AMD, i would like to reinstall it, would the "reset my pc" feature work for... -
in Windows 10 Software and AppsNew PC Parts/Motherboard: Hi, im upgrading my entire pc, except for the storage and i want to know, can i reinstall windows, do i need to buy another licence, and how does that actually work?Since im switching from intel to AMD, i would like to reinstall it, would the "reset my pc" feature work for... -
20H2 update rendered my PC useless
in Windows 10 Installation and Upgrade20H2 update rendered my PC useless: I have an Alienware R8 with RTX 2070. I started off with that because people with a somewhat related issue are saying that they are stuck on the boot screen but in my case my computer displays nothing at all. After the update I can power up my PC and the lights on the desktop... -
KBB5003173 nearly made my PC useless
in Windows 10 Updates and ActivationKBB5003173 nearly made my PC useless: I found Windows had chosen to restart itself late tonight, installing that and KB4601554 on its own. Shortly after the PC began having screen issues followed by rebooting itself after 2-4 minutes. Event viewer shows multiple errors and warnings each time. Trying to go to a... -
useless update
in AntiVirus, Firewalls and System Securityuseless update: why was this update forced on people ? half the websites are blocked all of a sudden. this "new" version is garbage , not user friendly to try to undue all the changes it did . you should just bring back the old explorer version. how do you unblock the internet... -
New PC parts, BSOD
in Windows 10 BSOD Crashes and DebuggingNew PC parts, BSOD: Hi, everybody, A week and a half ago I replaced most parts of my PC. At first Windows ran fairly stable, but I had some crashes and crashed some heavier games after a while. To exclude that the problems were caused by the Windows installation taken from the old system, I... -
w10 useless
in Windows 10 BSOD Crashes and Debuggingw10 useless: OK so 1st off = no sound eventually after many hours/days I downloaded something that worked, no tanks to microsoft. 2nd problem device driver recognises my 2 nd h/drive bit not windows, great can't acces music videos docs pics, really great.#Why you cant make something... -
Cortana Useless
in Windows 10 Drivers and HardwareCortana Useless: Got a new laptop and finally got Windows 10 to activate. Cortana doesnt respond AND I also want to print to a wireless printer direct like I do from my phone but all the directions talk about a network. I dont have a network nor do I have access to one. Can I print to an HP... -
Useless Taskbar
in Windows 10 SupportUseless Taskbar: Problem: Can't use Cortana search, open notifications or open the start menu. Can't run Insider Hub either I've been searching google all day and tried several methods with no results. * I created a powershell.exe file on the desktop and ran as administrator to use the...
