Windows 10: How do I fix the problem where my audio cuts out after every reboot/boot up sequence for...
Discus and support How do I fix the problem where my audio cuts out after every reboot/boot up sequence for... in Windows 10 Customization to solve the problem; I will go to turn on my pc and then I will join a discord server or turn on Spotify just to be RTC connecting on discord or Spotify won't let me... Discussion in 'Windows 10 Customization' started by Daxton1, Oct 28, 2020.
How do I fix the problem where my audio cuts out after every reboot/boot up sequence for... - Similar Threads - fix problem where
How do I fix a boot up problem?
in Windows 10 BSOD Crashes and DebuggingHow do I fix a boot up problem?: When I boot up my pc it boots up and then displays an error before booting up my operating system. It says “B1InitializeLibrary failed 0xc0000229” I have no idea what that means. If you could help that would be appreciated.... -
in Windows 10 GamingHow do I fix a boot up problem?: When I boot up my pc it boots up and then displays an error before booting up my operating system. It says “B1InitializeLibrary failed 0xc0000229” I have no idea what that means. If you could help that would be appreciated.... -
in Windows 10 Software and AppsHow do I fix a boot up problem?: When I boot up my pc it boots up and then displays an error before booting up my operating system. It says “B1InitializeLibrary failed 0xc0000229” I have no idea what that means. If you could help that would be appreciated.... -
Boot Sequence Problem
in Windows 10 GamingBoot Sequence Problem: So i've been setting up the boot sequence every time giving Kali Linux Boot USB highest priority, but it always boots as Windows Boot Manager, not allowing the setup of the Linux to initiate. I have created the Boot USB by Rufus, and works but still booting The USB always... -
in Windows 10 Software and AppsBoot Sequence Problem: So i've been setting up the boot sequence every time giving Kali Linux Boot USB highest priority, but it always boots as Windows Boot Manager, not allowing the setup of the Linux to initiate. I have created the Boot USB by Rufus, and works but still booting The USB always... -
Audio cuts in and out
in Windows 10 Software and AppsAudio cuts in and out: Audio has been having an issue way before build 22623.1037. It seems when Window has to load a program or do an activity. The audio cuts out and gets distorted while Windows 11 has to load something. Sometimes it does it when loading up a program like Steam or whatever, and... -
Every time I use my microphone all audio cuts out and mutes, Is there anyway to fix this?
in Windows 10 Ask InsiderEvery time I use my microphone all audio cuts out and mutes, Is there anyway to fix this?: I have never seen this issue before and I want to know how or if this can be fixed. submitted by /u/AnimatorExtreme [link] [comments] https://www.reddit.com/r/Windows10/comments/um0e7k/every_time_i_use_my_microphone_all_audio_cuts_out/ -
Audio cutting in an out
in Windows 10 Drivers and HardwareAudio cutting in an out: So basically my audio seems to be cutting in and out. I have tested the headset on other computers so I know it's not that. But the weird thing is that it doesn't seem to be happening when watching videos. Only when gaming or chatting. I have tried most basic things that I... -
Audio randomly cuts out every few minutes
in Windows 10 Drivers and HardwareAudio randomly cuts out every few minutes: This began to happen fairly recently, probably over the past few days. My audio is cutting out/lagging randomly when listening to Spotify and/or playing games for example. I'm using a DGX Xonar 5.1 soundcard for my toslink hi-fi system, as well as bluetooth headphones and...
