Windows 10: How do I restore sound settings to default in control panel?
Discus and support How do I restore sound settings to default in control panel? in Windows 10 Customization to solve the problem; I have a laptop with Windows 10 1909. I wanted to record internal audio from my phone using Audacity on my laptop. To get Audacity working, I had to... Discussion in 'Windows 10 Customization' started by Shubh Varma, Jul 15, 2020.
  1. How do I restore sound settings to default in control panel?
    I have a laptop with Windows 10 1909. I wanted to record internal audio from my phone using Audacity on my laptop. To get Audacity working, I had to make some changes in sound settings from Control panel. The changes made were not fruitful because when I start recording I hear nothing except a glitched loud noise, these changes did nothing but gave me more problems.
    Now, after making these changes I am facing problems with my audio.
    I attend meetings on Microsoft Teams and the mic and speakers do not work, the same happens with zoom. I cannot hear anyone and no one can hear me.
    I doubt the changes made in Sound settings from Control Panel to cause this.
    Is there any way I can restore the settings from Control Panel?
    You can revert back if you want some screenshots of the settings I have done, but please get me out of this.
    Thanks in advance!
  2. dalchina Win User
    How do I change the default setting for .eml files?
    Try rt clicking an eml file, Open With, and carefully follow through the several steps to assign your chosen program completely as default.
    Also try
    How do I restore sound settings to default in control panel? [​IMG]
    Set this program as default (but in your case for Mailbird). (Or the equivalent in Settings)
    Note that eml files are not a default file type in Windows (i.e. not in the relevant Tutorial list here Restore Default File Type Associations in Windows 10 Windows 10 Customization Tutorials ) i.e. teh file type has to be established by a program.
    Also make sure this is set correctly:
    (or the equivalent in the Control Panel)
    dalchina, Jul 15, 2020
  3. Arul_D Win User
    In Windows 10 how do I return the font on my desktop icons to the default setting?
    Welcome to the Microsoft Community.
    I would suggest you to follow the below steps and check if you are able to restore to default font settings in windows 10.
    • Type fonts in the search and press enter
    • Click on Font settings
    • Click on Restore default font settings.
    Keep us posted if you face any issues on windows in future. We will be glad to help you.
    Arul_D, Jul 15, 2020
  4. How do I restore sound settings to default in control panel?
    How do I restore my default desktop display settings?
    My name is Angel. I am an Independent Advisor. Thanks for contacting our support
    Step 1
    Find your "Desktop Personalization Settings." Turn on your computer and wait for your desktop to load. Right click on your desktop and click on "Personalize" to be taken to your desktop settings. Click "Change Desktop Icons" under "Tasks" and double click "Restore
    Default."
    Step 2
    Go to "Taskbar and Start Menu Properties" under "Tasks" and click "Customize." Scroll down the menu and click on "Restore Default Settings." Select "Notification" and click "Customize" and double click "Default Settings." Click the "OK" button at the bottom
    of all the tabs to apply the settings you just established.
    Step 3
    Restore default your desktop appearance and sounds. Click on "Desktop" under the "Personalization" menu. Click in the check box next to each of the display settings that you wish to return to default settings. Click "Customize" once you have selected all of
    the settings and click "Restore Default." Reboot your computer for the changes to take effect and to return your desktop to the default factory settings.
    Angel
    AngelCarreno, Jul 15, 2020
  1. How do I restore sound settings to default in control panel? - Similar Threads - restore sound settings
  2. Sound Control Panel
    Sound Control Panel: Ever since the new windows updates, Sound Control Panel , also known in the bottom right (from sounds - speaker) as Playback Devices / Recording Devices, this tab has been taken out and we were given some option not many care about (even if they do, a lot of people never...
  3. how do I open Control Panel
    how do I open Control Panel: Where is Control Panel? https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-open-control-panel/57000368-e1aa-43db-94b3-06f0e8ca9bec
  4. Sound ICON in Control panel will not open sound settings.
    Sound ICON in Control panel will not open sound settings.: Control panel will open, but when I click on sound, It errors with [ATTACH] This has been bugging me for awhile now, and I have struggled trying to fix it... I need to boost the mic I use for skype as the volume is too low. Windows 10 64 bit OS Several other Icons in...
  5. Control Panel Sounds
    Control Panel Sounds: Device Disconnect makes a sound while computer is in sleep mode. How do I turn it off? https://answers.microsoft.com/en-us/windows/forum/all/control-panel-sounds/4c65c3d3-48e9-43c9-8531-bb29344b98a1
  6. How do i restore default typing settings?
    How do i restore default typing settings?: thank you https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-restore-default-typing-settings/4e36c5b8-4c76-4d33-8a46-a5c42cf7012e
  7. How do I restore default icons from control panel?
    How do I restore default icons from control panel?: Hello this is my first post I installed a custom icon pack and I didn't like so I decided to uninstall it but after I uninstalled it everything went back to normal except the ones in the control panel (Which I didn't get why) I did had a restore point but that actually didn't...
  8. 'Settings' Default is not= Control Panel 'Default Programs' - All
    'Settings' Default is not= Control Panel 'Default Programs' - All: Hi, An observation, not a question. I wanted to set Thunderbird as my default email client again (after having reset defaults whilst looking for a problem). So I set it as my default email client in 'System', 'Default Apps'. This proved not to be the same as using...
  9. Sound Control Panel
    Sound Control Panel: Hi.Running a Windows 10 computer.Running headless using Remote Desktop.Only use the computer as a music server.Have a dac connected to computer.In sound panel under playback it's only option is Remote Audio.Dac and other options are not there.Right click to show disabled and...
  10. No sound, No Control Panel
    No sound, No Control Panel: Installed Win10 and have the following problems. 1) I have no sound; Sound icon on task bars says "No audio Output Device Installed." When I run troubleshooter, it says Troubleshooting couldn't detect the problem. 2) Control Panel: When I click on control panel it...
