Windows 10: How do I use the default audio device for everything except Edge, and a different device...
Discus and support How do I use the default audio device for everything except Edge, and a different device... in Windows 10 Network and Sharing to solve the problem; I need to use the default audio device, 01 "Speakers Realtek High Definiti" for everything except for Edge. For Edge and Edge only, I would like to... Discussion in 'Windows 10 Network and Sharing' started by VerlanKliewer, Nov 5, 2020.
How do I use the default audio device for everything except Edge, and a different device... - Similar Threads - default audio device
How do I set a different default volume per audio device on Windows 11?
in Windows 10 GamingHow do I set a different default volume per audio device on Windows 11?: So on Windows 10 I could have my laptop speakers permanently muted, and sound would only play when my bluetooth headset was connected.I can't figure out how to do that in Windows 11. In System -> Sound I can set the Speakers default as 'mute' and the Headphones default as... -
in Windows 10 Software and AppsHow do I set a different default volume per audio device on Windows 11?: So on Windows 10 I could have my laptop speakers permanently muted, and sound would only play when my bluetooth headset was connected.I can't figure out how to do that in Windows 11. In System -> Sound I can set the Speakers default as 'mute' and the Headphones default as... -
How do i tell windows to allow everything to use my devices?
in Windows 10 GamingHow do i tell windows to allow everything to use my devices?: I have any thing playing, everything thing else is mute. I dont get it. It only allows one device a time to use audio, everything else gets denied. Same thing goes for the mic. I have my PS controller plugin and I can no longer use my mic. I unplugg the controller, I can use... -
in Windows 10 Software and AppsHow do i tell windows to allow everything to use my devices?: I have any thing playing, everything thing else is mute. I dont get it. It only allows one device a time to use audio, everything else gets denied. Same thing goes for the mic. I have my PS controller plugin and I can no longer use my mic. I unplugg the controller, I can use... -
in Windows 10 BSOD Crashes and DebuggingHow do i tell windows to allow everything to use my devices?: I have any thing playing, everything thing else is mute. I dont get it. It only allows one device a time to use audio, everything else gets denied. Same thing goes for the mic. I have my PS controller plugin and I can no longer use my mic. I unplugg the controller, I can use... -
App volume and Device Preferences not routing audio to different different devices on launch.
in Windows 10 CustomizationApp volume and Device Preferences not routing audio to different different devices on launch.: Hello, I am having the same issue as a another post. The only way I can get audio to send to this device is to change the output to somewhere else, then back to the device again - every single time the app is restarted. This happens with not all, but with multiple different... -
How do I install an audio device ?
in Windows 10 Drivers and HardwareHow do I install an audio device ?: How do I install an audio device ? https://answers.microsoft.com/en-us/windows/forum/all/how-do-i-install-an-audio-device/a0d5f6b8-60ec-458d-9f86-b994c3dadb3e -
App volume and Device Preferences not routing audio to different different devices.
in Windows 10 Drivers and HardwareApp volume and Device Preferences not routing audio to different different devices.: As the subject says I have been having this trouble when trying to route the audio for programs to different devices it doesn't work. I can choose the device but it doesn't actually change where the audio is going. I have already tried closing the program and restarting it in... -
How to set an app to use Default Communication Device instead of Default Playback device
in Windows 10 Drivers and HardwareHow to set an app to use Default Communication Device instead of Default Playback device: In my Windows 10 system, I have multiple audio devices. Ex: TV as HDMI monitor, USB Speakers, Headset connected to the front panel Headphone/Mic ports. [ATTACH] [ATTACH] Most applications use the Default Playback device (currently set to USB Speakers as indicated by the...
