Windows 10: how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and...
Discus and support how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and... in Windows 10 BSOD Crashes and Debugging to solve the problem; too many processes running on my windows 10. i turned up background apps btu there are still 99 processes. Thanks... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by paulaE., Nov 20, 2021.
  1. paulaE. Win User
  2. windows 10 running slow
    Welcome to Microsoft community.
    I would suggest you to run System maintenance troubleshooter.
    Try the followings steps:
    • Click "Search" and type "Troubleshooting" without quotes and hit enter.
    • Select "System maintenance"
    • Click next to run the troubleshooter.
    Hope this helps.
    Waseemulla S, Nov 20, 2021
  3. System 32 files/ programs runs for a while and disappears on Windows 10
    Hi Konstantin,
    Thank you for posting in Microsoft Community and being a part of Windows 10.
    I understand the inconvenience you are facing with the processes running on the operating system. Do not worry we will help you with this issue.
    Provide us additional information to assist you better with this issue:
    • What is the complete error message/ error code of this issue?
    • Have you made any changes to the operating system prior to this issue?
    • When exactly does this issue persists?
    I suggest you to try the below troubleshooting steps and check if it helps.
    Step 1: I suggest you to sign-out from the current user account, restart the computer, resign-in and check with the status of this issue.
    Step 2: I suggest you to run SFC scan and check if it helps.
    System File Checker is a utility in Windows that allows users to scan for corruptions in Windows system files and restore corrupted files. If a
    Windows Resource Protection (WRP) file is missing or is corrupted, Windows may not behave as expected.
    Follow the below steps:
    • Right click on the Start button, click on
      Command Prompt (Admin).
    • Type “sfc /scannow” without the quotes and hit
      Enter.
    • After the scan, restart the computer and check for the issue.
    Step 3: Also, I suggest you to install all the pending updates on Windows 10.
    • Connect to the internet.
    • Press Windows key and type
      updates
    • Click on Check for updates.
    • Under Windows Updates, click on
      Check for updates.
    • Try to install the updates being shown.
    Hope it helps. Kindly update the status of this issue with the required information for further assistance.
    Deepika Gowda, Nov 20, 2021
  4. Sajer Win User
    Win 10 How to get rid of Windows.old folder and content.
    *Think
    As always, there seems to be lots of alleged fixes out there, which may work on versions earlier than Win 10... but not with Win 10. The struggle for getting rid of this now un-needed bloat seems to be wrapped up in file permissions. But even when I try to clobber it with administrative authority, it won't budge. One fix suggests that you can use disk cleanup to get rid of it by selecting previous installation files. Heh. Yeah. Just TRY and find that option in Win 10.
    Ok. Somebody hopefully has managed to resolve this inigma. Step by step, please. how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and... :)
    Sajer, Nov 20, 2021
  1. how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and... - Similar Threads - many system rocesses
  2. What is this and how do I get rid of it
    What is this and how do I get rid of it: I factory reset my pc and now this thing is on my taskbar. im not really sure what it is and i wanna get rid of it, but rightclicking it does nothing...
  3. What is this and how do I get rid of it
  4. What is this and how do I get rid of it
  5. What is this icon and how do I get rid of it?
    What is this icon and how do I get rid of it?: [ATTACH] submitted by /u/OkMeasurement420 [link] [comments] https://www.reddit.com/r/Windows10/comments/uc2g6v/what_is_this_icon_and_how_do_i_get_rid_of_it/
  6. how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and...
    how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and...: too many processes running on my windows 10. i turned up background apps btu there are still 99 processes. Thanks https://answers.microsoft.com/en-us/windows/forum/all/how-many-system-p-rocesses-shoudl-be-running-in/bc8404ef-67c9-4c1d-8752-7d005c0bd2b5
  7. how many system p rocesses shoudl be running in fwindows 10 and what do i get rid of and...
  8. What is this and how do I get rid of it (Windows 10 Pro, NOT running in S mode)
    What is this and how do I get rid of it (Windows 10 Pro, NOT running in S mode): [ATTACH] submitted by /u/TheTaquitoverlord [link] [comments] https://www.reddit.com/r/Windows10/comments/i3qd29/what_is_this_and_how_do_i_get_rid_of_it_windows/
  9. what is this and how do i get rid of it.
    what is this and how do i get rid of it.: how do i uninstall this? https://twitter.com/KidozyGAME/status/1184926861551382530/photo/1 https://answers.microsoft.com/en-us/windows/forum/all/what-is-this-and-how-do-i-get-rid-of-it/f8214419-e8c6-49f2-9b90-b7ac466a3fcc
  10. What is this "feature" and how do I get rid of it?
    What is this "feature" and how do I get rid of it?: I just rebooted my computer (updated to W10 about 2 weeks ago), and now all of the sudden it wants me to enter a password, for some kind of Microsoft account – this is before I can get to my desktop. They do cleverly tell you how to reset the password at live.com, and I do...
