Windows 10: How to automatically sleep when the laptop is switched/running on battery power battery...
Discus and support How to automatically sleep when the laptop is switched/running on battery power battery... in Windows 10 Performance & Maintenance to solve the problem; I have a problem with my laptop's battery, so I need help to create a task in Task Scheduler tosleep when the laptop is switched/running on battery... Discussion in 'Windows 10 Performance & Maintenance' started by - Christoffel -, Apr 24, 2020.
How to automatically sleep when the laptop is switched/running on battery power battery... - Similar Threads - automatically sleep laptop
Battery and Power Question for laptops
in Windows 10 Ask InsiderBattery and Power Question for laptops: If I were to set the "when I close the lid" setting to do nothing, but set the "Hibernate after this amount of time" to 10 min. Will the computer hibernate after the 10 min if I shut the lid? Or will it continue to run? Basically I want to be able to shut the lid but if I... -
Battery & Power
in Windows 10 Performance & MaintenanceBattery & Power: Hello, So when my laptop battery is low and turns blank, and I charge it before it completely shuts down, the Screen will still remain blank but it's still on....the screen won't come back on even though it's charging...I will have to shut it down with the power button and... -
BSoD when switching to battery.
in Windows 10 BSOD Crashes and DebuggingBSoD when switching to battery.: The title explains. I have update chip set, bios, and all drivers available to windows update and support assist. I am using a Dell precision m6800. Here is some of the things that caused the crashes: [ATTACH] I have had issues every once in a while saying that ac power... -
Sleep when the laptop is on battery power via Task Scheduler
in Windows 10 Performance & MaintenanceSleep when the laptop is on battery power via Task Scheduler: I have a problem with my laptop's battery, so I need help to create a task in Task Scheduler tosleep when the laptop is switched/running on battery powerAND the battery is below 96%. I also want this task to run every time the system starts. Using the advanced power setting... -
Laptop crashes on battery power
in Windows 10 BSOD Crashes and DebuggingLaptop crashes on battery power: I have Windows 10 running on my laptop. After a recent update the battery life icon vanished. I followed the instructions in the settings to switch it back on but now the laptop crashes without warning. It acts like the battery is dead but it is a months old battery and it... -
Power cord not running laptop but is charging battery.
in Windows 10 CustomizationPower cord not running laptop but is charging battery.: My laptop is currently charging with the power cord but does not seem to be running it at all. The battery is depleting while I am using the laptop to the point that it will shutdown because of low battery even though it is plugged in. Battery will then charge. Icon bar at... -
Battery Backup For Laptop When Power Outage?
in Windows 10 SupportBattery Backup For Laptop When Power Outage?: Hey all got a question. I have a dell xps 15 9550 laptop and i have it charged into outlet almost always. But if i disconnect it from outlet, i get around 2 hour battery life at the most it seem before i have to recharge it. The thing is when im doing certain things, i have... -
BSOD when laptop runs on battery
in Windows 10 BSOD Crashes and DebuggingBSOD when laptop runs on battery: Hey guys, I hope someone can help with this. I upgraded my Alienware laptop to windows 10 several months ago but only recently did I try running it on battery power and found out that it repeatably/seemingly randomly crashes. So far this ONLY seems to happen when running on... -
Laptop switching on and running the battery down from Hibernate
in Windows 10 SupportLaptop switching on and running the battery down from Hibernate: I'm still new to Windows 10 (home), from XP and recently bought a new HP laptop. I always leave the laptop with a full battery and hibernate overnight, with mains power turned off and the lid open. In the past week I noticed twice that the battery was about 80% in the morning...
