Windows 10: How to clear browsing data of Edge Legacy using Edge Chromium
Discus and support How to clear browsing data of Edge Legacy using Edge Chromium in Windows 10 News to solve the problem; [ATTACH]The latest Chromium-based Microsoft Edge web browser has replaced your classic legacy Edge browser. The new Edge Chromium brings you the option... Discussion in 'Windows 10 News' started by WinClub, Jul 16, 2020.
  1. WinClub New Member
  2. How to clear Browsing Data in Microsoft Edge?
    Hello
    CCLeaner cannot yet clean the cache of Microsoft Edge. You can clean your browsing data by following these steps.
    • Open Microsoft Edge
    • Click on the three little dots on the top right corner
    • Under Clear Browsing Data click on Choose what to clear
    • Then make sure Cache is checked
    • Click on Clear
    If you don;'t understand exactly what I mean
    then see this post
    for a detailed step by step instruction with images.
    Hope it helps you!
    Yuri
    Yuri Pustjens, Jul 16, 2020
  3. zapd Win User
    This does not work. I get this "Some data couldn't be cleared. Please try again." Windows 10 Version 1511 (OS Build 10586.218)
  4. Vonnjy Win User
    One step missing:
    • **Settings
    • Click on Clear
    Vonnjy, Jul 16, 2020
  1. How to clear browsing data of Edge Legacy using Edge Chromium - Similar Threads - clear browsing data
  2. Edge Clear browsing data on close not working
    Edge Clear browsing data on close not working: If Edge is not deleting cache when you exit the browser, even after enabling this feature, this article will be helpful. As there could be various reasons, we have consolidated some of the most common and widely encountered ones, along with solutions to get rid of this...
  3. Legacy Edge and Chromium Edge side by side?
    Legacy Edge and Chromium Edge side by side?: Hello, I would like to have legacy Edge and chromium Edge side by side. Unfortunately, I don not know how to. I've followed a lot of on;ine tutorials, but I still do not know how to do so. Can someone help, please? Thanks....
  4. Latest update changes pinned legacy edge shortcut to Edge Chromium
    in Browsers and Email
    Latest update changes pinned legacy edge shortcut to Edge Chromium: Can anybody who has both legacy Edge and Edge Chromium installed verify this unacceptable behaviour. I did the regedit to retain Legacy Edge and that works fine, and in apps list I see both Edge Chromium and Legacy Edge. I pin Legacy Edge to Taskbar and it works fine. I...
  5. Latest update changes pinned legacy edge shortcut to Edge Chromium
  6. How to run Legacy Edge and Chromium Edge side by side in Windows 10
    How to run Legacy Edge and Chromium Edge side by side in Windows 10: [ATTACH] [ATTACH]Microsoft Edge updates will be tied with Windows Update, starting with the release candidate, It will not allow you to use the older version or Legacy version of Edge anymore. Any attempt will launch the Chromium version of Edge. However, [...] This post How...
  7. Browsing Data Slow to Clear in Edge.
    Browsing Data Slow to Clear in Edge.: I have updated to Win V. 1903. Since the update it takes ages for Browsing Data to clear in Edge. Prior to the update it used to clear almost as soon as I clicked the button. Any thoughts please? 133872
  8. Edge displays blank screen & can't delete clear browsing data
    Edge displays blank screen & can't delete clear browsing data: When I open Edge it opens to a blank start page & usually below I see weather time etc & customize & now I cant see anything. I went to Microsoft site & did everything it says. I also noticed browser slow also & not displaying many things on sites. I did a Internet Explorer...
  9. Clear Browsing Data in Microsoft Edge in Windows 10
    in Windows 10 Tutorials
    Clear Browsing Data in Microsoft Edge in Windows 10: How to: Clear Browsing Data in Microsoft Edge in Windows 10 How to Clear your Browsing Data in Microsoft Edge in Windows 10 Microsoft Edge is a new web browser added in Windows 10, and will be available across the Windows 10 device family. It is fast, compatible, and...
  10. Turn On or Off Clear Browsing Data on Exit of Microsoft Edge
    Turn On or Off Clear Browsing Data on Exit of Microsoft Edge: How to: Turn On or Off Clear Browsing Data on Exit of Microsoft Edge How to Turn On or Off Clear Browsing Data on Exit of Microsoft Edge in Windows 10 Microsoft Edge is a new web browser that is available across the Windows 10 device family. It is designed for Windows...
