Windows 10: How to enable two-finger-click for right-click?
Discus and support How to enable two-finger-click for right-click? in Windows 10 Ask Insider to solve the problem; I just got a brand new Windows 10 Lenovo laptop, but I immediately discovered that i can't two-finger-click to right-click, which I am used to from my... Discussion in 'Windows 10 Ask Insider' started by /u/oz1sej, May 31, 2020.
How to enable two-finger-click for right-click? - Similar Threads - enable finger click
Click with two fingers to right click doesnt disable on Touchpad
in Windows 10 Drivers and HardwareClick with two fingers to right click doesnt disable on Touchpad: Hello, I want to disable the two finger click right click on my touchpad. This is especially relevent when using a browser so that two finger clicking on a link opens that link in a new tab. I am aware that there is a setting in the touchpad menu that lets you disable "Tap... -
in Windows 10 GamingClick with two fingers to right click doesnt disable on Touchpad: Hello, I want to disable the two finger click right click on my touchpad. This is especially relevent when using a browser so that two finger clicking on a link opens that link in a new tab. I am aware that there is a setting in the touchpad menu that lets you disable "Tap... -
in Windows 10 Software and AppsClick with two fingers to right click doesnt disable on Touchpad: Hello, I want to disable the two finger click right click on my touchpad. This is especially relevent when using a browser so that two finger clicking on a link opens that link in a new tab. I am aware that there is a setting in the touchpad menu that lets you disable "Tap... -
Disabling two finger right click on touchpad
in Windows 10 GamingDisabling two finger right click on touchpad: Hi!I would like to know if there is a way to disable the two finger right click on the touchpad. Just to be as clear as possible, I do mean "click" and not "tap".I would like to have it so that the only time I right click is when I touch the bottom right corner of the... -
in Windows 10 Software and AppsDisabling two finger right click on touchpad: Hi!I would like to know if there is a way to disable the two finger right click on the touchpad. Just to be as clear as possible, I do mean "click" and not "tap".I would like to have it so that the only time I right click is when I touch the bottom right corner of the... -
How to enable Two Finger Tap for Right Click in Windows 11/10
in Windows 10 NewsHow to enable Two Finger Tap for Right Click in Windows 11/10: [ATTACH]If you are looking for ways to enable two-finger tap for right-click on Windows 11/10, then this post will help you. One of the most basic features that we use on a Windows OS is to right-click anywhere on the desktop or a file/folder to open the context menu and... -
Looking for clarification on how two-finger right-click works
in Windows 10 Drivers and HardwareLooking for clarification on how two-finger right-click works: I've recently purchases a mid-2019 Razer Blade 15 base model, and have been having issues with the two-finger right-click not tap. I'm finding that the function only works if I remove both fingers from the touchpad before clicking. If I keep one finger on the touchpad to... -
Touchpad won't right-click with two fingers or scroll
in Windows 10 BSOD Crashes and DebuggingTouchpad won't right-click with two fingers or scroll: I have a MacBook pro and used bootcamp. Everything was working fine until a blue cursor started to show up. Then afterwards, I could not scroll or use my right-click on my touchpad. I have tried every option shown, including uninstalling it, disabling it and everything I... -
synaptics - Two finger click to right click not working
in Windows 10 Drivers and Hardwaresynaptics - Two finger click to right click not working: Hi, I have synaptics touchpad installed and even though two finger click is enabled in the synaptics control panel, it still does not allow me to. It seems it is only that gesture that's not working as two finger scroll works, so does all 3 finger and 4 finger gestures....
