Windows 10: how to fix device settings not migrated for audio output
Discus and support how to fix device settings not migrated for audio output in Windows 10 Gaming to solve the problem; windows update was installed yesterday, and now every time the laptop lid is shut, the audio that was previously playing stops and no there is no sound... Discussion in 'Windows 10 Gaming' started by Anissa Indge, Jan 25, 2025.
how to fix device settings not migrated for audio output - Similar Threads - fix device settings
in Windows 10 Software and Appshow to fix device settings not migrated for audio output: windows update was installed yesterday, and now every time the laptop lid is shut, the audio that was previously playing stops and no there is no sound output until the device is shut down/restarted. I have tried to troubleshoot the issue and have attempted to update the... -
How to fix No Audio Output device is installed
in Windows 10 GamingHow to fix No Audio Output device is installed: I have been searching for the last 2 days and have tried every suggested fix and nothing. I have checked the drivers but I am unsure if I have the correct ones. Sound DOES work if I plug in a speaker but it doesnt if I am running through HDMI. I have went into the device... -
in Windows 10 Software and AppsHow to fix No Audio Output device is installed: I have been searching for the last 2 days and have tried every suggested fix and nothing. I have checked the drivers but I am unsure if I have the correct ones. Sound DOES work if I plug in a speaker but it doesnt if I am running through HDMI. I have went into the device... -
in Windows 10 Drivers and HardwareHow to fix No Audio Output device is installed: I have been searching for the last 2 days and have tried every suggested fix and nothing. I have checked the drivers but I am unsure if I have the correct ones. Sound DOES work if I plug in a speaker but it doesnt if I am running through HDMI. I have went into the device... -
Is there any way to fix "Device settings not migrated"???
in Windows 10 GamingIs there any way to fix "Device settings not migrated"???: Hello, I having an issue that my USB hub not detecting any device that connects to it while it only receives power. When I check on the device manager, there is no issue found overall but when I check the device events, it there is a problem while migrating to the windows... -
in Windows 10 Software and AppsIs there any way to fix "Device settings not migrated"???: Hello, I having an issue that my USB hub not detecting any device that connects to it while it only receives power. When I check on the device manager, there is no issue found overall but when I check the device events, it there is a problem while migrating to the windows... -
Audio input and output device is not migrated
in Windows 10 Drivers and HardwareAudio input and output device is not migrated: Few days ago suddenly my laptop internal audio is stopped working . I can use my headphones just fine, but the internal speaker itself is not working. At first I thought it was a problem with the sound , but after going to device manager , I found out that speaker and... -
How to fix "no audio output device is installed"
in Windows 10 Drivers and HardwareHow to fix "no audio output device is installed": I recently did a clean install of Windows 10. Now I don't have a speaker installed on my computer. When I hover over the sound icon, I get a message that says no audio output device is installed. [ATTACH] It doesn't show up in device manager either How do I remedy this?... -
Device Not Migrated - Audio Output Stopped Working
in Windows 10 Drivers and HardwareDevice Not Migrated - Audio Output Stopped Working: So, I was watching a video today. Paused it, left to go grab a snack, came back, and suddenly there was no more audio. I tried reinstalling drivers, troubleshooting multiple times on two different headsets, hard reboot, running command prompt, updating drivers, and no dice....
