Windows 10: How to move volume icon from primary monitor taskbar to secondary monitor taskbar?
Discus and support How to move volume icon from primary monitor taskbar to secondary monitor taskbar? in Windows 10 Customization to solve the problem; move or duplicate, either works for me... Discussion in 'Windows 10 Customization' started by WilliamSithiphong, May 7, 2020.
How to move volume icon from primary monitor taskbar to secondary monitor taskbar? - Similar Threads - move volume icon
How to move the taskbar on the secondary monitor and leave primary monitor with no taskbar ?
in Windows 10 GamingHow to move the taskbar on the secondary monitor and leave primary monitor with no taskbar ?: Hello world,I would like to retrieve the old way to move the taskbar as it use to be on Windows 10 and other windows before.Having the main monitor for the programs and the secondary for taskbar, tools, browsers, etc is the most comfortable to use for me.Using windowskey +... -
in Windows 10 Software and AppsHow to move the taskbar on the secondary monitor and leave primary monitor with no taskbar ?: Hello world,I would like to retrieve the old way to move the taskbar as it use to be on Windows 10 and other windows before.Having the main monitor for the programs and the secondary for taskbar, tools, browsers, etc is the most comfortable to use for me.Using windowskey +... -
Can you put the taskbar on a secondary monitor and not on the primary monitor?
in Windows 10 GamingCan you put the taskbar on a secondary monitor and not on the primary monitor?: I want to have my secondary monitor have my taskbar and all my shortcuts and my primary monitor be solely for display. Is there a way to only have the taskbar visible on a secondary monitor without setting that monitor as my primary monitor. I've tried setting the other... -
in Windows 10 Software and AppsCan you put the taskbar on a secondary monitor and not on the primary monitor?: I want to have my secondary monitor have my taskbar and all my shortcuts and my primary monitor be solely for display. Is there a way to only have the taskbar visible on a secondary monitor without setting that monitor as my primary monitor. I've tried setting the other... -
Move the taskbar on the secondary monitor and leave primary monitor with no taskbar
in Windows 10 GamingMove the taskbar on the secondary monitor and leave primary monitor with no taskbar: Hi.I would really appreciate more taskbar positioning options for the taskbar in Windows 11. I would really like to move the taskbar on the secondary monitor and leave primary monitor with no taskbar. If it is possible to do, I would really appreciate to know how. I already... -
in Windows 10 Software and AppsMove the taskbar on the secondary monitor and leave primary monitor with no taskbar: Hi.I would really appreciate more taskbar positioning options for the taskbar in Windows 11. I would really like to move the taskbar on the secondary monitor and leave primary monitor with no taskbar. If it is possible to do, I would really appreciate to know how. I already... -
Dual Monitors Taskbar Problem - Taskbar moves from secondary to primary monitor on wake
in Windows 10 Ask InsiderDual Monitors Taskbar Problem - Taskbar moves from secondary to primary monitor on wake: I'm running dual monitors (1440p main, 1080p secondary) and I want my taskbar positioned on my secondary monitor. After the computer wakes up from sleeping the taskbar is always repositioned back to the primary monitor. 1) I will not reassign my 1440p main display to be the... -
Excel taskbar button will not move to secondary monitor
in Microsoft Office and 365Excel taskbar button will not move to secondary monitor: I just upgraded to Windows 10 from Windows 7 Home There is a problem, when I open two or more excel .xlsx files and move them to secondary monitor, the excel taskbar button will not appear on the taskbar of the secondary monitor. The excel taskbar button will only appear... -
Taskbar keeps moving back to primary monitor
in Windows 10 SupportTaskbar keeps moving back to primary monitor: Pretty much as the title says. My task bar is locked and located on the right-hand side of my second monitor. Occasionally I'll go for it and realize that it is now located on the right-hand side of my primary monitor. Most recently this happened after bringing my computer...
