Windows 10: HP 15-dy1038nr fans always run high when plugged into power, not when on battery
Discus and support HP 15-dy1038nr fans always run high when plugged into power, not when on battery in Windows 10 Ask Insider to solve the problem; [ATTACH] submitted by /u/thegeekpea [link] [comments]... Discussion in 'Windows 10 Ask Insider' started by /u/thegeekpea, May 19, 2020.
HP 15-dy1038nr fans always run high when plugged into power, not when on battery - Similar Threads - dy1038nr fans always
Laptop crashed when plugged in on power with no battery plugged in
in Windows 10 Performance & MaintenanceLaptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the... -
in Windows 10 GamingLaptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the... -
in Windows 10 Software and AppsLaptop crashed when plugged in on power with no battery plugged in: Hie . My laptop carshes every 5-10min when ever i am working on it. First is checked with The power is plugged in and the battery also it crashed. Then i removed the battery and connected directly to power plugged in it crashes again. Can anyone help me figure out what is the... -
Fans run at high speed when the computer is in idle
in Windows 10 GamingFans run at high speed when the computer is in idle: I just upgraded to windows 11. Everything was fine, until I changed in the power options the "put the computer to sleep" to 3 hours. After some time without using the computer I don't know exactly how long, i would say 30 minutes or so, the fans speed up for some reason. When... -
in Windows 10 Software and AppsFans run at high speed when the computer is in idle: I just upgraded to windows 11. Everything was fine, until I changed in the power options the "put the computer to sleep" to 3 hours. After some time without using the computer I don't know exactly how long, i would say 30 minutes or so, the fans speed up for some reason. When... -
Power usage and excessive fan kicking in when running off battery
in Windows 10 BSOD Crashes and DebuggingPower usage and excessive fan kicking in when running off battery: Background ** For decades from the mid 70s to the late 90s I worked in the IT industry and for a Good time specialised on Operating Systems from those. running on huge but simple ferrite core non disk based systems to the bloatware of windows. I even wrote 2k room basic... -
HP Pavillion 15 Power/battery issue
in Windows 10 Performance & MaintenanceHP Pavillion 15 Power/battery issue: I have an HP Pavillion 15 Just recently I have been having trouble with my power/battery. I can charge up my laptop using the power cord when it its powered off, but when I turn on my laptop and attach the cord it will not charge while using. Is there a setting that I may... -
Save power mode when on battery or plugged in
in Windows 10 Ask InsiderSave power mode when on battery or plugged in: [ATTACH] Hey guys, Since v1903, unplugging or plugging in my AC adapter does not restore my desired power mode. By default, I would like my laptop to default to Battery Saver power mode when it is not plugged in and Better Performance power mode when it is plugged... -
power toggles between battery and AC when plugged in
in Windows 10 BSOD Crashes and Debuggingpower toggles between battery and AC when plugged in: how can I fix issue with power constantly toggling from battery to AC when plugged in. I have rebooted and run all windows 10 updates. I also tried the power cycling my laptop as well as power troubleshooting....
