Windows 10: I deleted several fonts from my PC a few days ago and now have a problem with some websites!
Discus and support I deleted several fonts from my PC a few days ago and now have a problem with some websites! in Windows 10 Ask Insider to solve the problem; [ATTACH] So, I decided to delete a few fonts I never use from my PC. But I think I deleted an important font for internet browser. Because now,... Discussion in 'Windows 10 Ask Insider' started by /u/rlf_93, Sep 23, 2020.
  1. /u/rlf_93 Win User
    I deleted several fonts from my PC a few days ago and now have a problem with some websites! FGC6f6xFUOsQ4e1ke2rRQ9uLXKTwp1qV7Kx399tC-ZY.jpg
    But I think I deleted an important font for internet browser. Because now, some websites have another font than before (it has been replaced) and the problem is that this new font is extremely hard to read (almost impossible) as it's extremely light...
    I tried with Edge, Chrome and Firefox, and I have the same problem. I think I deleted the 'standard internet font' accidentally. And I wish I could know which one so I can reinstall it.
    I have my problem on wikifandom for example:
    What I see with my font problem. As you can see, it's barely readable.
    https://shokugekinosoma.fandom.com/wiki/Shokugeki_no_Soma
    You probably see the page with another font that I deleted. Please help me find it so I can reinstall it. Thanks a lot!
    submitted by /u/rlf_93
    [link] [comments]
  2. NeoSOS Win User
    Fonts
    I found these steps in this forum from back in 2010:
    Step 1:
    I would suggest you to try these steps and check whether it helps in fixing your issue.
    Open font settings by clicking on start, click on control panel, and then click on appearance and personalization, under fonts click on change font settings. And select the font size.
    Step 2:
    If you’re trying to change windows font size then please follow the steps below:
    To change Windows fonts
    1. Open Appearance Settings by clicking the Start button and then clicking Control Panel. In the search box, type window color, and then click Change window colors and
    metrics
    2. In the Item list, click the part of Windows that you want to change the font for. For example, if you want to change the menu font, click Menu in the list. Then, make any of the following changes:
    · In the Font list, click the font that you want to use.
    · In the Size list, click the font size that you want.
    · In the Color list, click the font color that you want.
    3. Repeat these steps for each item that you want to make changes to, and then click OK.
    Does that help?
    NeoSOS, Sep 23, 2020
  3. FONTS
    I understand your inconvenience. We will assist you with it.
    I suggest you to follow the instruction provided below and check.
    Step 1:
    • Download the font type you want to install.
    • Right click and click on install.
    • Check if you are able to view the fonts in documents.
    Or
    Step 2:
    • Open Control Panel.
    • Click on fonts.
    • Now, drag and drop the downloaded fonts in the font’s folder.
    Hope this information helps. If you have any queries, let us know. Will be happy to assist you.
    Syed Md Bilal, Sep 23, 2020
  4. I deleted several fonts from my PC a few days ago and now have a problem with some websites!
    Deleting non-Latin fonts in Windows 10 Home
    Thanks for the suggestion, but, sadly, it does not. In addition, I have gone to the Font Management setting and followed Microsoft's directions explicitly. Win 10 will NOT let me delete any installed font (except ones that I have installed myself), and it will NOT let me hide any font at all. The 'Hide' setting says it will hide the font from applications, but EVERY application that offers a choice of fonts, whether from Microsoft (Office, Word, Wordpad, Notepad, etc.) or third parties (such as OpenOffice) shows ALL the fonts listed in the Font Management listing. Every. Single. One.
    There was a script for removing the non-Latin fonts from Win 7 that automated the process. That script does not work in Win 10. Is there one that does?
    Thanks in advance for any help/
    Bookbear1948, Sep 23, 2020
  1. I deleted several fonts from my PC a few days ago and now have a problem with some websites! - Similar Threads - deleted several fonts
  2. I installed a font, now some websites use it in replacement of other fonts.
    I installed a font, now some websites use it in replacement of other fonts.: A month or 2 ago I installed "Helvetica Neue 97 Black Condensed Oblique" and started to see the font used on random occasions while using Opera GX and I think some other programs, I try to uninstall the font and it tells me that I can't because it's in use even if I end all...
  3. I installed a font, now some websites use it in replacement of other fonts.
  4. I notice that some websites have thin font
    I notice that some websites have thin font: I noticed that all of my browser in my laptop that there are some website that has thin fonts but not all of them. I checked all the browser and it is all the same. I checked on my other device and it shows normal fonts. Before, I dont have this kind of behavior so Im...
  5. I notice that some websites have thin font
  6. I notice that some websites have thin font
  7. Several BSODs in a few days
    Several BSODs in a few days: Not much more than that. Several errors in this last week. Tried a lot. Sfc, Chkdsk, update drivers, restores older drvers, driver verifier, DISM, and more. Some of the BSOD erros, minidumps, and my specshttps://1drv.ms/u/s!AmgNMLdhtHyLkeoXtts3lKyHurvn5w?e=cxEoXbAnything I...
  8. Several BSODs in a few days
  9. Several BSODs in a few days
  10. Microsoft support just fixed my pc a few days ago. Now needing help
    Microsoft support just fixed my pc a few days ago. Now needing help: Ok I guess there was something wrong with the iso or something like that not to shore. But now that has been fixed I even had to create a new account which I kind of liked I started over from scratch but without losing my files. So here's the question that I have? How...
