Windows 10: I don't have any notice about low battery and another problem about notice sound
Discus and support I don't have any notice about low battery and another problem about notice sound in Windows 10 Customization to solve the problem; Hello everybody Problem #1: I have a problem when my level power lower then 10 percent I don't see any notice about power and my laptop turns off.... Discussion in 'Windows 10 Customization' started by Victor Dmitrishen, Oct 31, 2020.
  1. I don't have any notice about low battery and another problem about notice sound
    Hello everybody
    Problem #1:
    What I did:
    • I check all settings in control panel and all my settings are turned on
    • I did file recovery via command line and there are no any problems
    • I tried to decide my problem via "Detecting problems"
    • Recently, I changed my OC home to OC pro because I need the docker for work and It doesnt help me
    Problem #2
    I don't have any notice sound when I get some messages from Outlookgoogle.com
    What I did:
  2. error notice
    What was the content of this notice? (Or as much of it as you could read)
    Don
    Don Varnau, Oct 31, 2020
  3. low battery alarm
    We suggest that you check if the low battery notification is turned
    on. Kindly follow these steps:
    • On the search box, type Power Options to see the laptop's power plans.
    • Click on Change Plan Settings.
    • Click on the Change Advanced Power Settings.
    • Scroll down and look for Battery.
    • Expand it see Low battery notification, turn it on for both
      On battery and Plugged in.
    Let us know whenever you need further assistance.
    Nathaniel Mon, Oct 31, 2020
  4. I don't have any notice about low battery and another problem about notice sound
    low disk notice for local disk F.
    Since getting the latest update for windows 10, I keep getting a low disk space notice for local disk F..... why and what do I do to stoop this notice??
    BarbaraRamstad, Oct 31, 2020
  1. I don't have any notice about low battery and another problem about notice sound - Similar Threads - don't notice low
  2. Sound notication of a unknown process
    Sound notication of a unknown process: having a problem with sound notification, looks like processing is happening in the backgound as the screen display of mouse pointer disappears for under a second and reappears, and there is an annoying sound notification. Tried identifying the process. I am thinking there...
  3. Sound notication of a unknown process
  4. Low disk space notices
    Low disk space notices: I get frequent warnings that I have low disk space, even though I have pretty well off-loaded virtually everything to external drives. Windows 10 settings shows C: having a capacity of 913 GB, with 912 GB used and 534 MB free. D: shows a capacity of 16.7 GB with 15.1 GB used...
  5. Low disk space notices
  6. Low disk space notices
  7. i notice only certain videos don't have thumbnails?
    i notice only certain videos don't have thumbnails?: i made sure ot turn on an show thumbnails. i see the assassin creed trailers have no thumbnail? just a mp4 file logo? i downloaded them from youtube. im assuming not all files support thumbnails? not an issue since they are the only ones as of now don't have thumbnail...
  8. Notices about anti virus and firewall
    Notices about anti virus and firewall: Why do I constantly has notices come up saying my firewall is not up. It is up and the messages constantly come up that it is not there. https://answers.microsoft.com/en-us/windows/forum/all/notices-about-anti-virus-and-firewall/9c5e90a4-d894-4008-92a2-e7f01cccc7c2"
  9. Notice about cookies Interfering with my work.
    Notice about cookies Interfering with my work.: I see in my screen persistently a notice "A **** wants to use xxx cookies in your computer" I selected do not allow, blocked it. All this is not working This notice is annoying...
  10. Notice on startup about an external drive being connected
    Notice on startup about an external drive being connected: This thing slides into the lower right of the screen for about 5 seconds. Totallu unnecessary. Is there a way to get rid of it? 144429
