Windows 10: I have a problem, and must ask for help! After debloating with script, my "START MENU"...
Discus and support I have a problem, and must ask for help! After debloating with script, my "START MENU"... in Windows 10 Ask Insider to solve the problem; [ATTACH] submitted by /u/stari_dever [link] [comments]... Discussion in 'Windows 10 Ask Insider' started by /u/stari_dever, Aug 18, 2020.
I have a problem, and must ask for help! After debloating with script, my "START MENU"... - Similar Threads - problem must ask
Help have deleted start up menu
in Windows 10 GamingHelp have deleted start up menu: Was trying to get rid of a potential problematic file and deleted start menu exe and related files from subfolders. Start menu button still shows but nothing happens when I click on it or use the keyboard shortcut. Tried using powershell command posted on a previous thread... -
in Windows 10 Software and AppsHelp have deleted start up menu: Was trying to get rid of a potential problematic file and deleted start menu exe and related files from subfolders. Start menu button still shows but nothing happens when I click on it or use the keyboard shortcut. Tried using powershell command posted on a previous thread... -
in Windows 10 CustomizationHelp have deleted start up menu: Was trying to get rid of a potential problematic file and deleted start menu exe and related files from subfolders. Start menu button still shows but nothing happens when I click on it or use the keyboard shortcut. Tried using powershell command posted on a previous thread... -
DEBLOAT scripts - how to edit?
in Windows 10 SupportDEBLOAT scripts - how to edit?: I want to run a Debloat script on a new W10 installation, but first I'd like to go through it to see what's included\disincluded and maybe make some changes. How does one examine a script without activating it? 168548 -
Renabling windows update after debloat script
in Windows 10 Ask InsiderRenabling windows update after debloat script: Hello everyone, I am no sys admin so im having trouble with this. I recently ran a debloat script on my windows machine and I am super happy with how it left it apart from the fact that it remove the only windows program I actually use, One Note for windows 10. I tried to... -
My taskbar's right side is flooded with icons after running a debloat script
in Windows 10 Ask InsiderMy taskbar's right side is flooded with icons after running a debloat script: [ATTACH] submitted by /u/L4ndF4ll [link] [comments] https://www.reddit.com/r/Windows10/comments/jho8d4/my_taskbars_right_side_is_flooded_with_icons/ -
[HELP] Windows Start Menu Transparency Problem
in Windows 10 Ask Insider[HELP] Windows Start Menu Transparency Problem: Hello, I have a problem with my Windows start menu transparency. My taskbar is very transparent and I like it, but the start menu won't get transparent even a little no matter what I try. Why? I got the latest version of Windows 10 which is 2004 and I just can't fix it. Is... -
Windows Store is missing - Windows Debloater script
in Microsoft Windows 10 StoreWindows Store is missing - Windows Debloater script: Hi There Windows store is missing user account after using Windows Debloater script. I had 2 Local accounts and everything was fine after script was done. Once I created 3rd local account, Windows store was missing. 1. Trouble-shooter doesn't work 2. Cant reset-it... -
Taskbar, Start Menu, Icons Problems Help
in Windows 10 SupportTaskbar, Start Menu, Icons Problems Help: Hi, i am facing a really hard time with my windows 10 after upgrading from windows 7 (like 3 days ago), everything was working fine, but now my taskbar is having all kind of problems like literally, first start with my "Start Menu" it not functioning anymore, than the...
