Windows 10: I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i...
Discus and support I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i... in Windows 10 Software and Apps to solve the problem; I have my Asus tuf a17 2021. And it comes with dts x ultra. And it's working very fine. But for last 10-15 days it's not working. I mean when i click... Discussion in 'Windows 10 Software and Apps' started by Rajsahu7723, Nov 23, 2022.
  1. I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i...
    I have my Asus tuf a17 2021. And it comes with dts x ultra. And it's working very fine. But for last 10-15 days it's not working. I mean when i click on music mode it didn't gives any response. And not for all movie, voice etc. Mode. Please help.
  2. Asus TUF F15 FX506HCB DTS X: Ultra not working
    Hi all,
    I'm creating this thread because from all my searches I found post that are related to DTS X: Ultra won't work completely even for build in speakers but my issue is as below.
    A month ago I bought Asus TUF F15 FX506HCB. I'm have a strange problem with DTS X: Ultra. For Wired device (JBL Tune 110) & Build in speakers DTS X: Ultra works fine (it seems). For BT devices (JBL Flip 5 & Nokia TWS T3110), I get prompt "Please connect external speakers to use DTS audio controls. Please connect a Headphone to use DTS audio controls" (as attached image. This is taken from internet but issue is exactly the same). Even DTS X: Ultra is not showing in Spatial audio formats not for Wired, Wireless & Build in speakers.
    I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i... f90860c1-2565-47e6-a92e-66bef92612db?upload=true.png
    Does DTS X: Ultra won't work for wireless devices? even it doesn't, may be spatial audio should work for wired devices right? (what I understand from my Googling).
    I haven't tried HDMI audio routing.
    Any help or suggestion would be appreciated.
    Thanks.
    Subash Baskaran, Nov 23, 2022
  3. DTS:X Ultra Not working
    All I did was search a video up on YouTube and downloaded "DTS APO4X" and "DTS APO4X Service" i the video. The youtuber uploaded the links in the description.
    After you download both the DTS files, just open them and right click on the .inf files in both folders and click on the install button. Then once you install both of them, you should restart your computer
    After that for me, I opened the DTS X Ultra App and the interface seemed to work but nothing changed like in the equaliser I dragged the bars to +10 DB the sound didnt change and I tried different presets but it was just the same low decibel flat sound without DTS
    I asked about it here on the forum and for me a solution worked
    All I did after this was
    Click on the start menu, go to DTS X Ultra, right click, click on more, click on app settings, then just reset the app
    Then after a restart everything started working perfectly like it should have, high sound great bass and treble
    I have the ASUS TUF A15, Ryzen 5 4600H, GTX 1650
    Hope this helps you man this is exactly what I did.
    AnuragSingh_3000, Nov 23, 2022
  4. I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i...
    DTS Sound not working?
    HI Pranchal. I'm Greg, 10 years awarded Windows MVP, here to help you.
    Try these fixes for DTS Sound not working:
    9 Simple Ways to Get DTS Audio Control on Windows 10/11
    (Avoid ad links which intrude into editorial copy, especially DO NOT INSTALL Restoro, PC Repair Tool and Reimage ads)
    DTS Sound Unbound FAQ
    https://ugetfix.com/ask/how-to-fix-dtsx-ultra-n...
    https://h30434.www3.hp.com/t5/Desktop-Audio/DTS...
    https://www.thewindowsclub.com/dtsx-ultra-not-w...
    There are some sound enthusiast forums where you might get more help posting here:
    https://www.techpowerup.com/forums/threads/dts-...
    https://forums.stevehoffman.tv/threads/help-wit...
    https://www.avsforum.com/threads/dts-x-atmos.31...
    Report back results for each step so I know what else to suggest.
    Feel free to ask back any questions. Based on the results you post back I may have other suggestions if necessary.
    Greg Carmack - Veteran MVP - Volunteer Moderator, Nov 23, 2022
  1. I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i... - Similar Threads - Asus tuf a17
  2. DTS X-Ultra spatial sound
    DTS X-Ultra spatial sound: hi ! DTS X-Ultra does not appear ! https://answers.microsoft.com/en-us/windows/forum/all/dts-x-ultra-spatial-sound/d515a309-f030-4343-bcd7-bb4247216e50
  3. DTS X-Ultra spatial sound
  4. DTS X ULTRA NOT WORKING ON
    DTS X ULTRA NOT WORKING ON: I HAVE AN ASUS TUF 15 FX506HC LAPTOP I AM FACING ISSUES WITH MY DTS X ULTRA APP, WHENEVER I AM TRYING TO OPEN IT ITS JUST DISPLAYING AS IT HAS BEEN DISPLAYED IN THE ATTACHED SCREENSHOT. I HAVE TRIED REINSTALLING IT AND EVEN OTHER DRIVERS SUCH AS DTSAPO4SERVICE AND EVEN...
  5. DTS X ULTRA NOT WORKING ON
  6. DTS X not working on ASUS TUF GAMING F15 Laptop
    DTS X not working on ASUS TUF GAMING F15 Laptop: Hi, how is everything today?Anyways, I have an issue where whenever I try to use DTS X Ultra for my laptop, it doesn't seem to be working at all. I've tried everything I could including updates and even updating my bios but had no success at all. Another thing that I'm having...
  7. I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i...
    I have my Asus tuf a17 2021. dts x ultra not working its not changing sound effects, i...: I have my Asus tuf a17 2021. And it comes with dts x ultra. And it's working very fine. But for last 10-15 days it's not working. I mean when i click on music mode it didn't gives any response. And not for all movie, voice etc. Mode. Please help....
  8. Asus TUF F15 FX506HCB DTS X: Ultra not working
    Asus TUF F15 FX506HCB DTS X: Ultra not working: Hi all,I'm creating this thread because from all my searches I found post that are related to DTS X: Ultra won't work completely even for build in speakers but my issue is as below.A month ago I bought Asus TUF F15 FX506HCB. I'm have a strange problem with DTS X: Ultra. For...
  9. Asus TUF F15 FX506HCB DTS X: Ultra not working
  10. DTS X Ultra not working
    DTS X Ultra not working: So appereantly my Asus Tuf A15 Supports DTS X Ultra. I installed the drivers and the App on my Laptop. And there is a Button in the DTS X Ultra App where i should be able to turn the feature on or off. But it doesn't change the Sound Quality. Nothing Happens. Long story...
