Windows 10: I need help it says sign in and when I do it’s says create pin then it says it didn’t work...
Discus and support I need help it says sign in and when I do it’s says create pin then it says it didn’t work... in Windows 10 BSOD Crashes and Debugging to solve the problem; I start my computer up & sign into the Microsoft Account screen with my password. The next screen wants me to create a Windows Hello Pin & you can only... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by adog, Apr 13, 2023.
  1. adog Win User
    I start my computer up & sign into the Microsoft Account screen with my password. The next screen wants me to create a Windows Hello Pin & you can only click next. So I click next & get "SOMETHING WENT WRONG. We weren't able to set up your PIN. You can try again, or skip this step and set up a PIN later." I clicked retry over & over & got this same message. I click Skip for now & it brings me back to the sign in screen when I first turn my computer on. I cannot get into my computer at all. There is no start menu in the corner either to try to restart in safe mode. I don
  2. jujub403 Win User
    windows sign on says something went wrong pin is unavailable click to reset and it says will not reset
    jujub403, Apr 13, 2023
  3. WReinus Win User
    PIN stopped working Settings says PIN not available
    PIN stopped working Settings says PIN not available. Suddenly getting error code. Have to use pw to sign in. Fingerprint reader also unavailable, but suspect this is because PIN is gone. Tried deleting NGC file but no privileges.
    How do I fix this?
    WReinus, Apr 13, 2023
  4. I need help it says sign in and when I do it’s says create pin then it says it didn’t work...
    I Messed up selective startup, says PIN is not available, MS Store??
    Shared album - Scott Downey - Google Photos
    I should have left it alone, now I am really stuck here.
    I tried to boot safe mode and still this PIN isn't available message, then say open the app in MS Store?
    - - - Updated - - -
    Something happened and your PIN isn't available [SOLVED]
    This solution here how can it work, you can not sign into windows, so you cant use any windows gui. what crazy stuff people write
    - - - Updated - - -
    Fix “Something happened and your PIN isn’t available” in Windows 10 | Password Recovery
    I have no 'sign in options' on the screen like everyone says is there....
    - - - Updated - - -
    Something happened and your PIN isn’t available message on Windows 10 - Microsoft Watch
    how about this, does this command still work for today' windows 10 2h2o? let the admin login with no password?
    1. 6. Select “Command Line” in the “Advanced Parameters” section.
    2. If you manage to open the command line, type the following command and restart your computer:
      Network administrator / active: yes
    no, says an unknown command
    sdowney717, Apr 13, 2023
  1. I need help it says sign in and when I do it’s says create pin then it says it didn’t work... - Similar Threads - need help says
  2. Cant sign in, says i need to install and app
    Cant sign in, says i need to install and app: Trying to sign into my laptop be it prompts me that i need to install an app or something. I looked around and most people can use a restore point to fix it but for some reason when i tried that it said i didnt have enough storage for that restore point.I couldn't find...
  3. Cant sign in, says i need to install and app
  4. It says I need to get a new pin
    It says I need to get a new pin: So today I went on my pc to play some games with my friends and than it says I need to get a new pin so I just tried to reset my whole pc but keep my files and I put my right password in cause I have it n my notes and I checked it multiple times and it still said “incorrect...
  5. It says I need to get a new pin
  6. It says I need to get a new pin
  7. I need help it says sign in and when I do it’s says create pin then it says it didn’t work...
    I need help it says sign in and when I do it’s says create pin then it says it didn’t work...: I start my computer up & sign into the Microsoft Account screen with my password. The next screen wants me to create a Windows Hello Pin & you can only click next. So I click next & get "SOMETHING WENT WRONG. We weren't able to set up your PIN. You can try again, or skip this...
  8. I need help it says sign in and when I do it’s says create pin then it says it didn’t work...
  9. says i need to upgrade. says need pin says they sent a code .but did not receve one ***...
    in Windows Hello & Lockscreen
    says i need to upgrade. says need pin says they sent a code .but did not receve one ***...: i can not sign in . says need pin https://answers.microsoft.com/en-us/windows/forum/all/says-i-need-to-upgrade-says-need-pin-says-they/bcb8cb6a-73ef-4d38-9325-933b4af6e9b2
  10. Microsoft i need to say this.
    Microsoft i need to say this.: sadly, i was playing roblox filming a video, all of a sudden, i got a bsod.... i was sCARED! it was my first time. what do you think i should do? im so scared! but thank you for saving my pc....
