Windows 10: I need help setting up a Hotspot with Alfa R36A for home WiFi/Internet
Discus and support I need help setting up a Hotspot with Alfa R36A for home WiFi/Internet in Windows 10 Network and Sharing to solve the problem; This may not be the place to ask - but I'll try anyways. I have a motorhome parked at my house (my storage location). I'm trying to setup a Wifi... Discussion in 'Windows 10 Network and Sharing' started by CountryBumkin, Jan 8, 2019.
I need help setting up a Hotspot with Alfa R36A for home WiFi/Internet - Similar Threads - need help setting
I need help with my wifi settings.
in Windows 10 GamingI need help with my wifi settings.: I have a wifi adapter in my computer for now , it’s an old one and only runs the 2.4ghz wifi. I don’t know too much about networks just from what i’ve read trying to connect this adapter and fix it. It keeps going up and down the connect and then when it gets so low it just... -
in Windows 10 Software and AppsI need help with my wifi settings.: I have a wifi adapter in my computer for now , it’s an old one and only runs the 2.4ghz wifi. I don’t know too much about networks just from what i’ve read trying to connect this adapter and fix it. It keeps going up and down the connect and then when it gets so low it just... -
in Windows 10 Network and SharingI need help with my wifi settings.: I have a wifi adapter in my computer for now , it’s an old one and only runs the 2.4ghz wifi. I don’t know too much about networks just from what i’ve read trying to connect this adapter and fix it. It keeps going up and down the connect and then when it gets so low it just... -
WiFi hotspot with no internet
in Windows 10 Network and SharingWiFi hotspot with no internet: WiFi hotspot with no internet I want to use the WiFi hotspot to create a LAN without the unreasonable demand that I have an internet connection to enable this feature. Without an uplink, the WiFi hotspot switch is greyed out for no reason at all, and I'm informed it's... -
I do not see Wifi and Mobile hotspot on my internet settings
in Windows 10 CustomizationI do not see Wifi and Mobile hotspot on my internet settings: Hi Team, Kindly need you help. My Internet settings does not have mobile hot spot and WiFi. What do I do?[ATTACH] https://answers.microsoft.com/en-us/windows/forum/all/i-do-not-see-wifi-and-mobile-hotspot-on-my/087c29b3-a662-4713-99aa-7ae36e7bdad6 -
in Windows 10 Network and SharingWiFi hotspot with no internet: I want to use the WiFi hotspot to create a LAN without the unreasonable demand that I have an internet connection to enable this feature. Without an uplink, the WiFi hotspot switch is greyed out for no reason at all, and I'm informed it's because there's no internet... -
Hotspot help needed
in Windows 10 Ask InsiderHotspot help needed: I'm connected to my own phone's hotspot for a short time and I tried to change the password as one periodically is want to do, however I can't for the life of me find a way to change the connection password on my Win10. I've checked all the places one should but there is no... -
Wifi Hotspot VPN Set up
in Windows 10 Network and SharingWifi Hotspot VPN Set up: Im trying to set up a hotspot with my windscribe vpn and when ever i try to log into the htospot with my phone it says " there might be no internet availability, what should i do?... -
No internet / wifi from hotspot
in Windows 10 Network and SharingNo internet / wifi from hotspot: So I have a Surface Pro 4 running windows 10 was working perfect this morning on my normal wifi. I pack it up to go somewhere and when I try to connect it to an iphone or iPad hotspot I just got it connected but with no internet. Both the ipad and iphone were getting internet...
alfa r36a set up
,afla r36A set up
,afla r36a open easy setup
