Windows 10: i need help with a problem wich i cant figure the cause
Discus and support i need help with a problem wich i cant figure the cause in Windows 10 Software and Apps to solve the problem; the general description is that since almost 3 years now, i have been getting this type of blue screen that doesnt let me do anything if i minimize the... Discussion in 'Windows 10 Software and Apps' started by NightHawk ., Jan 22, 2025.
i need help with a problem wich i cant figure the cause - Similar Threads - need help problem
in Windows 10 BSOD Crashes and Debuggingi need help with a problem wich i cant figure the cause: the general description is that since almost 3 years now, i have been getting this type of blue screen that doesnt let me do anything if i minimize the windows i am using. it doesnt let me use the windows key, the windows+r, i can refresh the drivers, but it stays, i can... -
in Windows 10 Gamingi need help with a problem wich i cant figure the cause: the general description is that since almost 3 years now, i have been getting this type of blue screen that doesnt let me do anything if i minimize the windows i am using. it doesnt let me use the windows key, the windows+r, i can refresh the drivers, but it stays, i can... -
I cant figure out the problem:
in Windows 10 GamingI cant figure out the problem:: DescriptionA problem with your hardware caused Windows to stop working correctly.Problem signatureProblem Event Name: LiveKernelEventCode: 1b8Parameter 1: 1Parameter 2: 0Parameter 3: 0Parameter 4: 0OS version: 10_0_22621Service Pack: 0_0Product: 768_1OS Version:... -
in Windows 10 Software and AppsI cant figure out the problem:: DescriptionA problem with your hardware caused Windows to stop working correctly.Problem signatureProblem Event Name: LiveKernelEventCode: 1b8Parameter 1: 1Parameter 2: 0Parameter 3: 0Parameter 4: 0OS version: 10_0_22621Service Pack: 0_0Product: 768_1OS Version:... -
BSODs need help figuring out cause
in Windows 10 GamingBSODs need help figuring out cause: Hello, getting hit with BSODs relentlessly. Mostly memory management or irql less equal. But once also saw a kernel related stop code. Windows keeps crashing in couple of minutes of reboot. Also, was unsuccessful with resetting the OS -- the pc somehow restarted in the middle... -
in Windows 10 Software and AppsBSODs need help figuring out cause: Hello, getting hit with BSODs relentlessly. Mostly memory management or irql less equal. But once also saw a kernel related stop code. Windows keeps crashing in couple of minutes of reboot. Also, was unsuccessful with resetting the OS -- the pc somehow restarted in the middle... -
in Windows 10 BSOD Crashes and DebuggingBSODs need help figuring out cause: Hello, getting hit with BSODs relentlessly. Mostly memory management or irql less equal. But once also saw a kernel related stop code. Windows keeps crashing in couple of minutes of reboot. Also, was unsuccessful with resetting the OS -- the pc somehow restarted in the middle... -
Need help with figuring out the causes of BSoD
in Windows 10 BSOD Crashes and DebuggingNeed help with figuring out the causes of BSoD: Hello, Recently, when I upgraded most of my components in my computer everything except GPU I have been getting these strange BSoDs. I've tried searching about them on different forums and concluded that this error does not have a defined answer on how to fix it, but its... -
Daily BSOD and i cant figure out the cause
in Windows 10 BSOD Crashes and DebuggingDaily BSOD and i cant figure out the cause: Hi everyone I am running Win 10 on my desktop. Specs are: MB: Gigabyte AX370 Gaming 3 GPU: GeForce GTX 1060 3 GB CPU: Ryzen 5 2600 6core RAM: 2x8 GB The lead up to my problem is that i had a BSOD event twice. A friend of mine suggested it could be a RAM problem and I tried...
