Windows 10: I need help with my audio devices. Can't switch consistently between them.
Discus and support I need help with my audio devices. Can't switch consistently between them. in Windows 10 Ask Insider to solve the problem; Hello all, I have an issue with audio devices on my computer, my G403 headset is connected to my zowie monitor via usb, I have an AOC monitor to which... Discussion in 'Windows 10 Ask Insider' started by /u/Elbananaso, Nov 12, 2019.
I need help with my audio devices. Can't switch consistently between them. - Similar Threads - need help audio
Rapid Switching Between Audio Devices
in Windows 10 GamingRapid Switching Between Audio Devices: I use an Audiobox USB audio interface for recording music but when I plug it in to my brand new laptop, it freaks out and rapidly switches between the audio interface and the built-in sound system, making the computer basically useless until I unplug it.The interface works... -
in Windows 10 Software and AppsRapid Switching Between Audio Devices: I use an Audiobox USB audio interface for recording music but when I plug it in to my brand new laptop, it freaks out and rapidly switches between the audio interface and the built-in sound system, making the computer basically useless until I unplug it.The interface works... -
where is my audio devices?? I need help
in Windows 10 Gamingwhere is my audio devices?? I need help: so my audio goes down and its the whole "speakers or headphones not plugged in message" when I made sure everything was plugged in, I try a few fixes and on one occasion my speaker devices are gone! Straight missing, I even checked the playback tab on the control panel, and... -
in Windows 10 Software and Appswhere is my audio devices?? I need help: so my audio goes down and its the whole "speakers or headphones not plugged in message" when I made sure everything was plugged in, I try a few fixes and on one occasion my speaker devices are gone! Straight missing, I even checked the playback tab on the control panel, and... -
in Windows 10 Drivers and Hardwarewhere is my audio devices?? I need help: so my audio goes down and its the whole "speakers or headphones not plugged in message" when I made sure everything was plugged in, I try a few fixes and on one occasion my speaker devices are gone! Straight missing, I even checked the playback tab on the control panel, and... -
Can't switch between sound devices anymore.
in Windows 10 CustomizationCan't switch between sound devices anymore.: Hello,I have Asus X55C running Windows 10 latest build and I noticed a problem that I can't switch between my Earphones connected at the headphone jack and the in-built speakers of laptop. If I want to switch them then I have to remove my earphones from the headphone jack. I... -
I can't switch my audio device.
in Windows 10 Drivers and HardwareI can't switch my audio device.: When i connect my headphones my computer thinks its still speakers so the sound switches to my headphones but i cant change it back to the actual speakers without unplugging my headphones.... -
Need help switching between three monitors
in Windows 10 Drivers and HardwareNeed help switching between three monitors: I have my computer connected to three screens. Two 1080p monitors and a 4k TV. I want to use the two monitors for regular use, but switch over to displaying on the TV for media consumption. Also, one of the two monitors I'm using is oriented vertically. My monitors are as... -
Unable to switch between Bluetooth audio devices
in Windows 10 Drivers and HardwareUnable to switch between Bluetooth audio devices: Hi, I just installed a csr dongle on my machine. I had no trouble finding and pairing both my Jabra earphones and a Sony speaker. The problem now is that I can't find a way to switch between the two. Only the Jabra earphones which were paired first work. The Sony speaker is...
