Windows 10: I really need help fixing this problem with BSOD and error code 0xc0000001
Discus and support I really need help fixing this problem with BSOD and error code 0xc0000001 in Windows 10 Software and Apps to solve the problem; This all started when I was trying to reset my windows 11 hp laptop because I had a problem with the audio but now I'm stop in a loop of BSOD and the... Discussion in 'Windows 10 Software and Apps' started by Ibuki Mioda cosplayer, Mar 24, 2023.
I really need help fixing this problem with BSOD and error code 0xc0000001 - Similar Threads - really need help
in Windows 10 GamingI really need help fixing this problem with BSOD and error code 0xc0000001: This all started when I was trying to reset my windows 11 hp laptop because I had a problem with the audio but now I'm stop in a loop of BSOD and the error code Error Code: 0xc0000001 I tried every solution I have seen on the internet and tried with hp live chat. I can't... -
Stuck on BSOD error code 0xc0000001
in Windows 10 GamingStuck on BSOD error code 0xc0000001: Hello, I'm currently stuck on BSOD. My PC keeps switching from turning on to BSOD. If I press recovery environment it sends me back to the screen and then 0xc0000098. Same with startup settings. I'm confused and I've been trying to reinstall windows, but it isn't working.... -
Error Codes: 0xc0000001 ; 0xc0000098 BSOD
in Windows 10 BSOD Crashes and DebuggingError Codes: 0xc0000001 ; 0xc0000098 BSOD: AMD Ryzen 5 2600x six core 3.60GHz16gb RAMNvidia GeForce GTX1660ti500gb SSD NVME1tb 7200rpm HDWin 10 Education 1909Back in April, I had a GPU driver update and also updated a couple of Adobe creative cloud apps in the same session. Since then I have been unable to boot -... -
in Windows 10 BSOD Crashes and Debuggingerror code 0xc0000001: have tried rebooting windows 10 with a usb drive. didnt work. cant find a solution to this problem really close to just returning the pc. if it helps i was deleting files not to sure if i deleted something important. i have gone 2 weeks without my pc but i need to access it... -
Error Code 0xc0000001
in Windows 10 Installation and UpgradeError Code 0xc0000001: Laptop will not boot correctly and gives only this error code and says the PC needs to be repaired https://answers.microsoft.com/en-us/windows/forum/all/error-code-0xc0000001/88a5c30d-3e69-4a7c-a2cf-f5da7fd71d6a -
BSOD of recovery error code 0xc0000001
in Windows 10 Installation and UpgradeBSOD of recovery error code 0xc0000001: Hi, I think i downloaded a virus and i was so worried. So i downloaded an app called anti-malware to scan and delete the virus. After done scanning or something, it forced me to restart. So i did it of course. And BSOD started occuring. Please help it is my dad's computer... -
how to fix error code 0xc0000001
in Windows 10 Installation and Upgradehow to fix error code 0xc0000001: Hi when i switch on my laptop i get this code 0xc0000001 i have pressed the windows key as instructed but it doesn't respond when i press the windows recovery option, can anyone help please... -
Error code 0xc0000001
in Windows 10 Performance & MaintenanceError code 0xc0000001: [ATTACH] Showing like this when i on my pc https://answers.microsoft.com/en-us/windows/forum/all/error-code-0xc0000001/06bfa45a-b0ee-422b-99c5-19fb5bf2236c -
in Windows 10 Installation and UpgradeError Code: 0xc0000001: This happed when I accidentally unplug the charger. So I was the laptop without it's battrey and the laptop was in the middle of resetting process then I accidentally unplug the laptop then as I open it, I got stuck at "Recovery Your PC couldn't start properly" blie screen. I...
