Windows 10: Intel SUR Queencreek not safe takes 45% power? Will not remove?
Discus and support Intel SUR Queencreek not safe takes 45% power? Will not remove? in Windows 10 Software and Apps to solve the problem; All Intel I-5,6 stepping on Acer rig. New current Intel Wifi application installed. Edge browser stall and Queencreek using 45% of capacity. Could not... Discussion in 'Windows 10 Software and Apps' started by R.L.PAIGE, Jun 15, 2024.
Intel SUR Queencreek not safe takes 45% power? Will not remove? - Similar Threads - Intel SUR Queencreek
in Windows 10 GamingIntel SUR Queencreek not safe takes 45% power? Will not remove?: All Intel I-5,6 stepping on Acer rig. New current Intel Wifi application installed. Edge browser stall and Queencreek using 45% of capacity. Could not control the apps take over, will not end, remove or shred. Intel update and consumer improvement removed before lockup of... -
intel UHD graphics with error code 45
in Windows 10 Drivers and Hardwareintel UHD graphics with error code 45: I have an intel i7-10750H processor in my laptop which is running windows 10.when I checked my task manager, I found out that my integrated graphic intel UHD graphic is not shown at the task manager so I checked with the device manager then there also, I am not able to find... -
QUEENCREEK problem
in Windows 10 CustomizationQUEENCREEK problem: It's been a few days that 360 Total Security has been reporting this message: The following program is attempting to inject code to another process. Block it immediately if unrecognized. Program: C:\Program Files\Intel\SUR\QUEENCREEK\x64\installer.bat Sources:... -
Intel Bluetooth Error Status 45
in Windows 10 Drivers and HardwareIntel Bluetooth Error Status 45: While connecting my jbl stone speakers bluetooth fails to do so. On troubleshooting it says no bluetooth found. In device manager Intel Wireless Bluetooth is having a code 45 error. In spite of the fact that my wireless mouse works easily. Bluetooth was working fine... -
Are these safe to remove
in Windows 10 SupportAre these safe to remove: Hi Guys I have on my pc the following items and I want to know if its safe to remove. As far as I know, I do not have/use any Apple products or machines. Apple Application Support 64 bit Apple Mobile Device Support Apple Software Update W 10 of course 159676 -
Thousands of HKEY entries Taking up memory-Safe to Remove? How to remove?
in Windows 10 BSOD Crashes and DebuggingThousands of HKEY entries Taking up memory-Safe to Remove? How to remove?: taking up 21 gb of memory https://answers.microsoft.com/en-us/windows/forum/all/thousands-of-hkey-entries-taking-up-memory-safe-to/216e74f4-6ffa-4692-86f8-ccb95976541f -
Is it safe to force power off by removing the battery?
in Windows 10 Ask InsiderIs it safe to force power off by removing the battery?: As the title says. My laptop PC is currently completely unresponsive; Ctrl + Alt + Delete doesn't work, keyboard and mouse inputs don't work. Screen is frozen at the time this happened, because the clock shows the time five minutes ago. What's even more baffling is that... -
Safe to remove
in Windows 10 Drivers and HardwareSafe to remove: On 1 of 4 1809 machines, I lost the "safe to remove message" The ports are ok and the usb stick is ok because the led goes out. Does anyone have a fix that "really" works ? Thanks 125584 -
Safe to remove
in Windows 10 SupportSafe to remove: On 1 of 4 1809 machines, I lost the "safe to remove message" The ports are ok and the stick is ok because the led goes out. Does anyone have a fix that "really" works ? Thanks 125584
