Windows 10: Internal monitor speakers showing up as audio device but not an audio output option
Discus and support Internal monitor speakers showing up as audio device but not an audio output option in Windows 10 Gaming to solve the problem; I am using a new Dell XPS 15 laptop Windows 11 connected via USB-C to a Dell 4K monitor via a Thunderbolt Dock. I'm keeping the laptop closed and using... Discussion in 'Windows 10 Gaming' started by vsrj, Feb 9, 2022.
  1. vsrj Win User
    I am using a new Dell XPS 15 laptop Windows 11 connected via USB-C to a Dell 4K monitor via a Thunderbolt Dock. I'm keeping the laptop closed and using only the external monitor. However, I cannot play audio through the monitor's integrated speakers. When I go to sound settings in Windows 11, I can only see the laptop's Realtek speakers listed. The monitor, however, is shown as an "audio" device on the devices page. How can I make the speakers inside the monitor show up as an audio output option? I have installed all Windows 11 and Dell XPS updates, including BIOS.
    vsrj, Feb 9, 2022
  2. No Audio Output Device is Installed
    You will need to select Windows 8 from the drop down list while installing the driver in compatibility mode.
    I would suggest you to try setting the speaker as default audio output by following the steps below and check if it helps.
    1. Right click on the sound icon on the right bottom corner of the taskbar.
    2. Select "playback devices".
    3. If "speaker" is not set as the default device, highlight it and click "set as default".
    5. Save the changes.
    Let us know the result.
    Wungraileng Vashi, Feb 9, 2022
  3. Windows 10 "No Audio Output Device is Installed" internal speakers
    Hello JRosales2112
    Please follow these steps
    Open Settings.
    Click on Update & Security.
    Click on Troubleshoot.
    Select the Playing Audio option.
    Click the Run the troubleshooter button.
    If That didn't work
    Try update or uninstall and reinstall the drivers
    How update drivers
    Go to Device Manager > select audio inputs and outputs > right click in the Speakers > Update driver
    If that didn't work
    Uninstall and install the drivers
    Go to Device Manager > select audio inputs and outputs > right click in the Speakers > Uninstall Restart your PC, and Windows will attempt to reinstall the driver.
    If Windows doesn't find a new driver, you can try looking for one on the device manufacturer's website and follow their instructions.
    I hope it helps
    Pedro V Flores, Feb 9, 2022
  4. netter Win User
    No audio output device
    Hello!
    I have a common problem: my Windows 10 has No Audio Output Device.
    System configuration:
    • Lenovo Legion Y520-15IKBN (laptop)
    • Windows 10 Pro, version 1909, build 18363.535;
    • Current updates;
    Device manager shows these audio devices:
    • High Definition Audio Device (driver version 10.0.18362.356)
    • Intel Display Audio (10.27.0.6)
    • ASUS Xonar U3 (10.0.8.2164)
    i.e. the problem persists even with an external (USB) audio device, recognized by the system.
    I performed a sanity check on this issue. Sound works when I boot into Ubuntu live. Therefore, it is not a hardware problem, and is indeed a Windows problem.
    Solutions that have not worked so far:
    1. Audio troubleshooter (issues found: check audio device, nothing else)
    2. Rolling back drivers
    3. Uninstalling audio devices
    4. Uninstalling any audio-related devices, incl. the likes of bluetooth speakers
    5. Updating audio drivers (from both built-in drivers and from manufacturer's site)
    6. Installing a generic audio device (installing a generic USB audio device does not succeed, and installing a generic Realtek device resulted in a BSOD)
    Do you have any ideas for fixing this?
    netter, Feb 9, 2022
  1. Internal monitor speakers showing up as audio device but not an audio output option - Similar Threads - Internal monitor speakers
  2. Dell Vostro 15 3000 - Internal speaker not working/no audio output device available
    Dell Vostro 15 3000 - Internal speaker not working/no audio output device available: I have been having problems with my Dell Vostro forever and a day. The internal laptop speakers just stopped working quite a while back and I've been trying to find a solution on and off for this but with no luck so far. I am able to pick up external devices bluetooth,...
  3. Dell Vostro 15 3000 - Internal speaker not working/no audio output device available
  4. No audio internal speakers
    No audio internal speakers: Hi there, Recently I was getting my bluetooth hooked up in my windows 10 Lenovo 940 and to send my sound through to my bluetooth speakers I had to manage my speakers and hook them up. Now I am ready to change back to the speakers built into my laptop, but I could not find...
  5. No audio internal speakers
  6. No audio internal speakers
  7. Internal monitor speakers showing up as audio device but not an audio output option
    Internal monitor speakers showing up as audio device but not an audio output option: I am using a new Dell XPS 15 laptop Windows 11 connected via USB-C to a Dell 4K monitor via a Thunderbolt Dock. I'm keeping the laptop closed and using only the external monitor. However, I cannot play audio through the monitor's integrated speakers. When I go to sound...
  8. No audio output devices installed but devices show up on device manager
    No audio output devices installed but devices show up on device manager: Hi, my PC always has a red cross on the sound icon at the taskbar whenever I turn it on. I take a look at the sound settings on the control panel and there are no audio devices listed at the playback menu. I look at the device manager and there are literally 5 audio devices...
  9. No audio from internal speakers
    No audio from internal speakers: I am running Windows 10 on an HP Spectre x360. My audio driver is the Realtek. Over the past month or so the internal microphone and speakers in my laptop have not been working. Sometimes they work for 5-10 minutes in the morning after I hadn't been on it in a while. After...
  10. Windows 10 "No Audio Output Device is Installed" internal speakers
    Windows 10 "No Audio Output Device is Installed" internal speakers: I had this laptop since January of this year, 2018, and I use Windows 10 on here. The laptop itself is an HP Omen and the internal speakers are not being detected, in its place is something when I right click it called "Speaker Setup (Unknown)" as if it is detecting a...
