Windows 10: Is it true that syncing between Edge Insider Beta (Chromium) and Android Edge STILL...
Discus and support Is it true that syncing between Edge Insider Beta (Chromium) and Android Edge STILL... in Windows 10 BSOD Crashes and Debugging to solve the problem; Hello, Yesterday I installed Edge Chromium Beta on my Windows 10 laptop through Windows Insiders, after having read that at least favorites should... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by Sjaak99, Nov 4, 2019.
Is it true that syncing between Edge Insider Beta (Chromium) and Android Edge STILL... - Similar Threads - true syncing between
Edge Chromium not syncing my Collections
in Browsers and EmailEdge Chromium not syncing my Collections: I've been using Edge Chromium for quite some time and everything was running perfectly, until days ago. Maybe was after a recent Windows 10 upgrade. It just stopped syncing my Collections. I would add a Collection and I would see the Collection added to the tablet and iPhone... -
Edge Chromium
in Windows 10 CustomizationEdge Chromium: Hi All, * We have installed edge chromium 84.0.522.63 offline installer and it has upgraded the inbuilt microsoft edge. * Current edge chromium 84.0.522.63 got upgraded automatically after an update edg chromium 86.0.622.38 has got installed from windows update. *But... -
Edge Chromium syncing question
in Browsers and EmailEdge Chromium syncing question: In the new Edge Chromium the Personal profile for your Microsoft Account has listed under Profiles/Sync a Turn On Sync option. In order for it to work..Does it also require Sync Settings to be turned on in Settings/Accounts/Sync Your Settings? If I have all Sync Settings... -
Import favorites from Edge Chromium Beta instead of Edge
in Windows 10 Network and SharingImport favorites from Edge Chromium Beta instead of Edge: I have been using Edge Chromium Beta for some time now and all relevant favorites are now on that browser. I cannot find a way to export the favorites from the beta version so I can delete the old Edge favorites and import them into the new Edge that comes with build 2004.... -
Edge Chromium - Beta Next to Stable?
in Windows 10 Ask InsiderEdge Chromium - Beta Next to Stable?: I wasn't sure if this was the correct sub-reddit for this so apologies!! Is anyone else seeing the Beta icon remaining on the desktop even though they've installed the stable version of Edge Chromium? If so, did you figure out how to get rid of it? Is it considered a... -
Microsoft Edge Chromium Beta
in Windows 10 Ask InsiderMicrosoft Edge Chromium Beta: [ATTACH] with the latest update version 83.0.478.25 (Official Build) beta (64-bit) it now lets you Sync Extensions from Google Chrome note i taken the picture from my other computer that has Microsoft Edge Chromium Beta on it then the one that im using to post this... -
Is Edge Chromium suppose to sync with the "original" Edge?
in Windows 10 Ask InsiderIs Edge Chromium suppose to sync with the "original" Edge?: I know both have sign on's to sync... and I imagine both want to sync toy our mobile device; but do they sync with each other? I haven't tried the mobile browser yet until I sort out the desktop, but i wasn't able to sync my regular "edge" favourites over to the chromium... -
Syncing Edge Chromium with Google account
in Windows 10 Ask InsiderSyncing Edge Chromium with Google account: Hello, How can I sync Edge Chromium with my Google account and automatically sync bookmarks and extensions? My goal is use browsers interchangeable with Google account synced and have bookmarks and extensions in sync in both browsers. Is this possible? I enabled external... -
Edge Chromium Beta
in Browsers and EmailEdge Chromium Beta: I am using Edge Chromium Beta ( and i think its very good ) is it possible to remove the "normal' Edge or do i have to wait for Microsoft to release the new version...and when they do will it automatically remove the old version. 143939
