Windows 10: Is it true that with wireless mice clicks sometimes will not register? and they have input lag?
Discus and support Is it true that with wireless mice clicks sometimes will not register? and they have input lag? in Windows 10 Gaming to solve the problem; Hi, i just got this mouse: Amazon.com: Hcman Gaming Mouse Wired,Programmable 7 Buttons,[Upgraded Version] Led Backlit & 5 DPI Mode,Comfortable Grip... Discussion in 'Windows 10 Gaming' started by SandyPlayz86, Jan 8, 2021.
Is it true that with wireless mice clicks sometimes will not register? and they have input lag? - Similar Threads - true wireless mice
Using 2 Wireless Mice
in Windows 10 Drivers and HardwareUsing 2 Wireless Mice: Is it possible to connect (wirelessly) a second wireless mouse to the same USB port and have them both work simultaneously? Thanks 171499 -
in Windows 10 SupportUsing 2 Wireless Mice: Is it possible to connect (wirelessly) a second wireless mouse to the same USB port and have them both work simultaneously? Thanks 171499 -
Lagging input
in Windows 10 Ask InsiderLagging input: I have Lenova tower about two years old and with wireless keyboard and mouse. Last year, I started experiencing lagging issues. This is a real problem with typing email or word document. Does anyone have this problem and have a solution. I looked for help on YouTube and... -
Recommendation for wireless mice
in Windows 10 Drivers and HardwareRecommendation for wireless mice: I'm trying to look for a wireless mouse to replace the one I have right now. However, it seems that despite my seemingly low requirements, I can't find something that seems satisfactory. Right now, I'm using a Dell WM514p which, while good enough, doesn't have back/forward... -
Wireless Comfort Keyboard 5050/ keys sticking/lagging/or not registering.
in Microsoft Windows 10 StoreWireless Comfort Keyboard 5050/ keys sticking/lagging/or not registering.: Im using the Wireless Comfort Keyboard 5050 and while typing it would randomly not register a key stroke. I repeatedly needed to go back and try th letter or number again. Sometimes it will add it or add 5 of them because it was lagging an I pressed the key multiple... -
Regarding wireless keyboards and mice
in Windows 10 BSOD Crashes and DebuggingRegarding wireless keyboards and mice: For 25 years I've turned on monitor, speakers, and computer every day. Now I'm considering an all-in-one desktop. Just one AC plug, just one button! But I find that most of them now use "wireless" keyboards and mice. My questions: Do these have to be turned on and off every... -
Mouse left click sometimes registering as 'back' button, Dell
in Windows 10 Drivers and HardwareMouse left click sometimes registering as 'back' button, Dell: Hi, I have a Dell latitude E7440. I have been experiencing odd behaviour since I got it second hand (fresh installation of refurbisher's windows 10 on arrival). At first I assumed that I had accidentely hit a key and when I realised that it was a computer issue I waited to... -
Wireless input devices lag under CPU load
in Windows 10 GamingWireless input devices lag under CPU load: Hi, I have experienced issues regarding my Wireless input devices (Logitech Unifying Receiver mouse & keyboard, Bluetooth Wireless Controller) during gaming. Both receivers are plugged into USB 3.0 ports and in almost immediate proximity. When idle, or performing simple... -
lag on mouse sometimes
in Windows 10 Performance & Maintenancelag on mouse sometimes: Hello when i upgrade my windows seven to ten, i face usually with mouse lag, this is not ever, but usually i see this when i run system for 5hours.. in seven i was okay, but in ten windows i see this issue usually. Thanks. 57959
