Windows 10: Is there a way to enable wireless without a key? Or can I get another way of using a hotkey...
Discus and support Is there a way to enable wireless without a key? Or can I get another way of using a hotkey... in Windows 10 Ask Insider to solve the problem; I need to enable my laptop's wireless. It doesn't have an physical switch, so I need to use the shortcut Fn + F4... but my F4 is not working. I have... Discussion in 'Windows 10 Ask Insider' started by /u/dumbestdumbstupid, Apr 4, 2020.
Is there a way to enable wireless without a key? Or can I get another way of using a hotkey... - Similar Threads - enable wireless without
Is there a way to disable global Windows hotkeys?
in Windows 10 GamingIs there a way to disable global Windows hotkeys?: Basically I set up some global hotkeys for my app such as WinKey+Home/End/-/+, and Function keys, but Windows steals the WinKey+Home/End/+ hotkeys and doesn't let me app to fire its own actions. I can see what Windows is doing with these global hotkeys but is there a way to... -
in Windows 10 Software and AppsIs there a way to disable global Windows hotkeys?: Basically I set up some global hotkeys for my app such as WinKey+Home/End/-/+, and Function keys, but Windows steals the WinKey+Home/End/+ hotkeys and doesn't let me app to fire its own actions. I can see what Windows is doing with these global hotkeys but is there a way to... -
Are there any way to have a hotkey for the screensaver?
in Windows 10 Ask InsiderAre there any way to have a hotkey for the screensaver?: Are there any way to have a hotkey for the screensaver? Like, I want to have it so that when I press Crtl + Alt + O it would trigger the Screensaver. submitted by /u/XTremeGameboy [link] [comments]... -
A Way Only Enable Touchpad mouse-Keys?
in Windows 10 Drivers and HardwareA Way Only Enable Touchpad mouse-Keys?: Hello everyone, Just as the tile asked, is there a way in Windows to only enable the left and right buttons of a laptop's touchpad? I mean, touchpad often comes with its surface sensing function, and at least two keys usually at the bottom as the left and right clicks of... -
Any ways to create a custom hotkey without bloatwear running in the background?
in Windows 10 Ask InsiderAny ways to create a custom hotkey without bloatwear running in the background?: Hi, so there's like a dozen different keyboard shotcut interrupt layers that enable custom shortcuts in windows, but I don't want to have to run bloated wares just to do one simple keyboard shortcut. I'm looking for the lightest lightweight solution possible to create a... -
Is there a way to use custom hotkeys while fullscreen?
in Windows 10 Ask InsiderIs there a way to use custom hotkeys while fullscreen?: I'm trying to set up a custom hotkey to mute my mic while in fullscreen games. I have everything set in a powershell script, which is called by a batch file to use the script, and send a command to a global class it creates. That's all working fine. I created a shortcut to... -
Is there a way to bind a hotkey to shutdown?
in Windows 10 Ask InsiderIs there a way to bind a hotkey to shutdown?: Incase an app crashes and refuses to close, even with task manager or Alt-F4 (this has happened, I had to hard reset). I've already looked into the "Choose what the power button does" but it has no option to change the sleep button to shutdown. Also, while I'm posting this,... -
Is there a way to get the windows installer on a usb without another pc?
in Windows 10 Ask InsiderIs there a way to get the windows installer on a usb without another pc?: Plan to install windows on a new pc. The only other PCs I have have viruses, so unless it’s ok to install the windows installer on a usb with a pc that has a virus, I don’t know what to do submitted by /u/xenos97 [link] [comments]... -
uninstall is there another way
in Windows 10 BSOD Crashes and Debugginguninstall is there another way: Why cant i uninstall this[ATTACH] https://answers.microsoft.com/en-us/windows/forum/all/uninstall-is-there-another-way/63a97353-efb4-4ce0-9757-75bc5b51e67f
