Windows 10: Is there a way to have default power settings when plugged in and unplugged? (automatically...
Discus and support Is there a way to have default power settings when plugged in and unplugged? (automatically... in Windows 10 Customization to solve the problem; I'd like the power saving settings to start and the screen to dim when unplugged. I have a dell xps 9570 with windows 10... Discussion in 'Windows 10 Customization' started by HelpMuhOut, Apr 8, 2019.
Is there a way to have default power settings when plugged in and unplugged? (automatically... - Similar Threads - default power settings
Turned on automatically when plugged in and off when unplugged
in Windows 10 Performance & MaintenanceTurned on automatically when plugged in and off when unplugged: Laptop just start misbehaving. It won't turn on except when plugged in, and it will off when unplugged despite displaying 94% at the battery bar.... -
in Windows 10 GamingTurned on automatically when plugged in and off when unplugged: Laptop just start misbehaving. It won't turn on except when plugged in, and it will off when unplugged despite displaying 94% at the battery bar.... -
in Windows 10 Software and AppsTurned on automatically when plugged in and off when unplugged: Laptop just start misbehaving. It won't turn on except when plugged in, and it will off when unplugged despite displaying 94% at the battery bar.... -
Is there a way to have a power plan set when certain applications are running?
in Windows 10 Ask InsiderIs there a way to have a power plan set when certain applications are running?: I suppose I could write a script for this but didn't want to reinvent a wheel. Google hasn't helped much however. Basically I have a power plan I call 'Super Saver' which is configured to save as much power (this computer is on 24/7) as possible while ensuring the PC doesn't... -
Can't adjust brightness when the power plugged or unplugged
in Windows 10 CustomizationCan't adjust brightness when the power plugged or unplugged: Hi there, Previous status: brightness 100%, plugged in; brightness 50%, unplugged. When I unplugged the laptop, the brightness will decrease down to 50%. And will increase back to 100% when the laptop plugged in back automatically. Current status: Always keep the... -
How to disable Brightness change when plugging in or unplugging power cord?
in Windows 10 BSOD Crashes and DebuggingHow to disable Brightness change when plugging in or unplugging power cord?: Saw a lot of discussion concerning this topic. Think I figured it out. As many of you have speculated it's not a Windows issue. It has to do with the OEM of your graphics chip. Most likely Intel or AMD. Each manufacturer has software that deals directly with the hardware.... -
Is there a way to see which device is unplugging and plugging itself in?
in Windows 10 Ask InsiderIs there a way to see which device is unplugging and plugging itself in?: I keep hearing the notification for a device unplugging and plugging back in, but I cannot for the life of me figure out which device it is. The noises are seconds apart. Is there a way to enable notifications or use 3rd party software to track which devices are being added?... -
Automatically change brightness when power cord is unplugged/plugged
in Windows 10 CustomizationAutomatically change brightness when power cord is unplugged/plugged: Hi, so on my laptop I used to have this feature where my screen brightness would dim/brighten whenever I had my power cord unplugged/plugged (to conserve battery life, etc etc.), whatever happened to that setting? Currently it's just 1 set brightness level for both scenarios... -
in Windows 10 BSOD Crashes and DebuggingHow to disable Brightness change when plugging in or unplugging power cord?: I absolutely hate the automatic brightness change that occurs when I plug in or unplug my power cord. How can I disable this?!...
power mode plugged in
,default power settings windows when plugged in
,brightness windows 10 plugged in vs unplugged
