Windows 10: is there solution for "fan running at fullspeed" after upgrading ?
Discus and support is there solution for "fan running at fullspeed" after upgrading ? in Windows 10 Drivers and Hardware to solve the problem; Hi ah, here it is : [img] microsoft driver : [img] right, ill try asking there. Discussion in 'Windows 10 Drivers and Hardware' started by Blitzhartwright, Mar 22, 2016.
  1. is there solution for "fan running at fullspeed" after upgrading ?
    ah, here it is :
    is there solution for "fan running at fullspeed" after upgrading ? [​IMG]
    microsoft driver :
    Blitzhartwright, Mar 24, 2016
    #16
  2. dalchina New Member
    Hi, fwiw I don't have spcdh.exe anywhere .. is it always using that much CPU time?
    You seem to be missing two ACPI-related items near the top of the list.
    Just wondering what you have for this (power button) given the ones missing:
    You could try updating all the ACPI drivers individually, but doubt that will achieve anything, unfortunately.
    Have a look at a fresh scan of DriverMax, and if not already done as above, try updating some drivers.. you shouldn't lose anything. Windows will cause them to revert to its version within a day without special action.
    dalchina, Apr 5, 2018
    #17
  1. is there solution for "fan running at fullspeed" after upgrading ? - Similar Threads - solution fan running
  2. Why is my PC fan running continuously ? Please suggest a solution .
    Why is my PC fan running continuously ? Please suggest a solution .: My desktop PC fan keeps running continuously . That's a huge noise. why is the problem persisting & how to resolve it ? My system specifications are : Windows 7 Professional ; Processor intel core 2 duo [Year 2006] ; DDR-2GB RAM [Two RAMs] ; a new smps & new motherhood...
  3. Why is my PC fan running continuously ? Please suggest a solution .
  4. Is there any possible solution for the reoccurring fan running at max speed problem? Or is...
    Is there any possible solution for the reoccurring fan running at max speed problem? Or is...: I've purchased an Asus ZenBook 14 UM433IQ a year ago and I have been encountering some weird issue with my laptop. When I normally use my laptop for a while and close the lid or stay AFK with the screen going off, when I reopen the lid or wake the laptop, the fan goes on full...
  5. Is there any possible solution for the reoccurring fan running at max speed problem? Or is...
  6. Fan running after update KB5004945
    Fan running after update KB5004945: Hello, after installing the KB5004945 update on the Dell Inspiron 7559 laptop, fan is often on even when watching a YouTube-only video or browsing simple websites! If I turn off the program or WebBrowser, the fan dies down. Fan's mechanically clean. I also tried pc Advanced...
  7. fan still running after hibernate
    fan still running after hibernate: Issue: It does NOT automatically power-off the laptop and fan still running after hibernate. Note: this happens almost 4out-of5 of times that I hibernate. It means almost 1out-of5 of times, it automatically power-off after hibernate. Steps: 1. I click on hibernate, it saves...
  8. Fan Running
    Fan Running: My cooling fan keeps running constantly blowing out cold air. Hardware checks show no problem. CPU usage can be as low as 2%. Sometimes it will stop after approx: 10 minutes and more times it can last as long as the laptop is powered up. Intel turbo boost turned off and...
  9. fan running continually after 2004 update
    fan running continually after 2004 update: Just updated Windows from 1909 to 2004, and now it seems the fan runs continually. Anyone else notice this? How to fix? https://answers.microsoft.com/en-us/windows/forum/all/fan-running-continually-after-2004-update/4c9feefe-b324-4377-be90-73dd08497d0f
  10. Fans Run after sleep mode
    Fans Run after sleep mode: Hi, is it normal in Windows 10 for a laptop fan to still run after putting the device to sleep? This is using the power button or sleep button from the start menu. This is on a Dell 5520 and an XPS 7390, does anyone happen to know? Also is it possible to see what could...
