Windows 10: Keep Console Open after running power shell script through task scheduler
Discus and support Keep Console Open after running power shell script through task scheduler in Windows 10 Network and Sharing to solve the problem; I am running a powershell script using task scheduler: Program/Script: C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe Add arguments... Discussion in 'Windows 10 Network and Sharing' started by HareshGP, Nov 5, 2020.
Keep Console Open after running power shell script through task scheduler - Similar Threads - Keep Console Open
Script for either a .bat file, or a CMD shell or Power Shell script, to automate running a...
in Windows 10 Network and SharingScript for either a .bat file, or a CMD shell or Power Shell script, to automate running a...: Windows 10Hello Is it possible to write a script for either a .bat file, or a CMD shell or Power Shell script, to automate running a single small .exe Snap2HTML.exe over and over again while stating the program parameters. I wish to use a small program called Snap2html... -
in Windows 10 Software and AppsScript for either a .bat file, or a CMD shell or Power Shell script, to automate running a...: Windows 10Hello Is it possible to write a script for either a .bat file, or a CMD shell or Power Shell script, to automate running a single small .exe Snap2HTML.exe over and over again while stating the program parameters. I wish to use a small program called Snap2html... -
Unknown Power shell script running
in Windows 10 GamingUnknown Power shell script running: Hi,I usually get a brief pop-up for a script that runs at random times as far as I can gather. Its only for a split second, but its a nuisance if I am gaming as my controller is just disabled until I swap out and back to the game window again.I can see that there are several... -
in Windows 10 Software and AppsUnknown Power shell script running: Hi,I usually get a brief pop-up for a script that runs at random times as far as I can gather. Its only for a split second, but its a nuisance if I am gaming as my controller is just disabled until I swap out and back to the game window again.I can see that there are several... -
Unable to generate hash id file through running script in Power Shell
in Windows 10 GamingUnable to generate hash id file through running script in Power Shell: Hi,After running the below script in Power Shell for generating hash id file for restting machine it showing below error and please check attached error.Script : Get-CimInstance -Namespace root/cimv2/mdm/dmmap -Class MDM_DevDetail_Ext01 -Filter "InstanceID='Ext' AND... -
in Windows 10 Software and AppsUnable to generate hash id file through running script in Power Shell: Hi,After running the below script in Power Shell for generating hash id file for restting machine it showing below error and please check attached error.Script : Get-CimInstance -Namespace root/cimv2/mdm/dmmap -Class MDM_DevDetail_Ext01 -Filter "InstanceID='Ext' AND... -
in AntiVirus, Firewalls and System SecurityUnable to generate hash id file through running script in Power Shell: Hi,After running the below script in Power Shell for generating hash id file for restting machine it showing below error and please check attached error.Script : Get-CimInstance -Namespace root/cimv2/mdm/dmmap -Class MDM_DevDetail_Ext01 -Filter "InstanceID='Ext' AND... -
Power shell script
in Windows 10 SupportPower shell script: Not sure where to post this. Can anyone tell me what this does. C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy UnRestricted function IJ($A) {$L = $Null;Get-ChildItem $A -Recurse -Depth 1 -ErrorAction 'SilentlyContinue' | ? {$_.extension -eq '.lnk'}... -
Task Scheduler doesn't run script
in Windows 10 Software and AppsTask Scheduler doesn't run script: Hey Microsoft Community, I'm trying to create a task in Task Scheduler that runs a specific script. The issue is that when the task runs (whether I do it manually or if it's scheduled), the script doesn't actually get executed. I know that the script works, and I have tried...
