Windows 10: Key board problem and shift problems
Discus and support Key board problem and shift problems in Windows 10 Software and Apps to solve the problem; basically for example if i wanted to do $ i will normally hold shift then press 4 but now i have to hold down shift and hold down 4 then let go of... Discussion in 'Windows 10 Software and Apps' started by Daian Ferdous Rahim, Dec 14, 2024.
Key board problem and shift problems - Similar Threads - Key board problem
in Windows 10 GamingKey board problem and shift problems: basically for example if i wanted to do $ i will normally hold shift then press 4 but now i have to hold down shift and hold down 4 then let go of shift to get $ which is very inconvenient... -
in Windows 10 GamingKey board problem and shift problems: basically for example if i wanted to do $ i will normanlly hold shift then press 4 but now i have to hold down shift and hold down 4 then let go of shift to get $... -
in Windows 10 Software and AppsKey board problem and shift problems: basically for example if i wanted to do $ i will normanlly hold shift then press 4 but now i have to hold down shift and hold down 4 then let go of shift to get $... -
keyboard problem with shift key
in Windows 10 Drivers and Hardwarekeyboard problem with shift key: when ever I press left shift I get the a bracket like this instead of just helping with writing capital letters and when I press right shift the whole written text gets deleted , please help me out I have been trying to find a solution on the net but couldn't find one , I... -
problem with Shift key
in Windows 10 Drivers and Hardwareproblem with Shift key: some of my keyboard keys are not working correctly, only when I use shift. Tried 3 different keyboards, all the same issue. but in bios setting working correctly I searched on the internet and I find the keyboard driver has an issue. I uninstall the driver many times and... -
my key board problem
in Windows 10 Customizationmy key board problem: what can i do https://answers.microsoft.com/en-us/windows/forum/all/my-key-board-problem/f468ea92-1c01-4015-9f2f-0b0671ebada2 -
Key Board Shift Key Issues
in Windows 10 Drivers and HardwareKey Board Shift Key Issues: Hi, I am on an HP laptop and my shift keys are not working on certain keys. The right shift key and left shift key do not always share keys that do not work in common. Please, can someone help me... -
shift key problems with Windows 10
in Windows 10 Software and Appsshift key problems with Windows 10: Not sure why this problem persists after it seemed to go away?? Right now I can use the question mark and the shift key but just 3 hours ago when I was using this same computer I could not use any of the shift key functions to capitalize nor to get special key strokes.... -
Problem with my shift key
in Windows 10 Drivers and HardwareProblem with my shift key: Hey, I use a Lenovo Thinkpad E431plus the latest update of Windows 10 on it. I recently started having a problem with my shift key, it switches on and off on its own and most times it stays on even without me pressing the shift key. This prevents me from typing in my pin...
