Windows 10: Keyboards not work on externally powered USB hub, but will work on PC
Discus and support Keyboards not work on externally powered USB hub, but will work on PC in Windows 10 Software and Apps to solve the problem; HelloI am having repeated issues with keyboard usage. I have tried with two different keyboards and encounter the same issues when plugging into the... Discussion in 'Windows 10 Software and Apps' started by BethR19, Dec 2, 2021.
Keyboards not work on externally powered USB hub, but will work on PC - Similar Threads - Keyboards externally powered
in Windows 10 GamingKeyboards not work on externally powered USB hub, but will work on PC: HelloI am having repeated issues with keyboard usage. I have tried with two different keyboards and encounter the same issues when plugging into the USB hub the PC cannot recognise the device. I have done countless driver uninstalls and restarts, and checked my power... -
in Windows 10 Drivers and HardwareKeyboards not work on externally powered USB hub, but will work on PC: HelloI am having repeated issues with keyboard usage. I have tried with two different keyboards and encounter the same issues when plugging into the USB hub the PC cannot recognise the device. I have done countless driver uninstalls and restarts, and checked my power... -
USB Hub not working
in Windows 10 GamingUSB Hub not working: My USB hub is not working j5 create 7 port usb hub JUH377When I plug things into the USB Hub I hear constant connecting and disconnecting sounds and none of the peripherals appearI've tried connecting the hub to all usb ports and the same issue occursI've connected other... -
USB Hub not working
in Windows 10 Software and AppsUSB Hub not working: My USB hub is not working j5 create 7 port usb hub JUH377When I plug things into the USB Hub I hear constant connecting and disconnecting sounds and none of the peripherals appearI've tried connecting the hub to all usb ports and the same issue occursI've connected other... -
USB Hub not working
in Windows 10 Drivers and HardwareUSB Hub not working: My USB hub is not working j5 create 7 port usb hub JUH377When I plug things into the USB Hub I hear constant connecting and disconnecting sounds and none of the peripherals appearI've tried connecting the hub to all usb ports and the same issue occursI've connected other... -
external USB hub not working property
in Windows 10 Drivers and Hardwareexternal USB hub not working property: I have a keyboard and mouse that share a single USB receiver. I also have a webcam and microphone sharing a single USB cable. I have a 2-port USB KVM switch with audio TK-209K. If I plug the the webcam/microphone cable directly into one of the USB port on the computer, both... -
USB Hub not working
in Windows 10 CustomizationUSB Hub not working: I have a new computer and a USB hub I used with my old computer is not being recognized not is any peripherals. I have done all the troubleshooting online with no success any suggestions?... -
mouse, keyboard and external speakers not working in usb hub.
in Windows 10 Drivers and Hardwaremouse, keyboard and external speakers not working in usb hub.: I have an external 3.0 usb hub plugged into my hp laptop. The light is on but my laptop does not recognize the mouse, keyboard and external speakers plugged into the hub. They only work when plugged into the laptop, but there is not enough room for all three items plus the... -
Powered usb external hard drive in powered usb hub
in Windows 10 Drivers and HardwarePowered usb external hard drive in powered usb hub: I have two powered USB 2.0 hard drives that I plan to plug into a powered USB 3.0 hub. I know I won't get the USB 3.0 speed, but should the I also connect each drive's power connection? Thank you for your help. 96467
