Windows 10: Laptop balanced power plan or power saver
Discus and support Laptop balanced power plan or power saver in Windows 10 BSOD Crashes and Debugging to solve the problem; My laptop vents has no dust and foreign matters, also i have cooling pad. But when cpu going to 100% caused by update, maintenance, etc, it can hurt my... Discussion in 'Windows 10 BSOD Crashes and Debugging' started by RendellSibal1, May 7, 2020.
Laptop balanced power plan or power saver - Similar Threads - Laptop balanced power
Other power plans are missing Theres only "balanced" power plan
in Windows 10 CustomizationOther power plans are missing Theres only "balanced" power plan: Other power plans are missing on me. I saw some videos on the YouTube about that but none of them worked! I saw it worked on some people but at me instead of getting other power plans, I have 4 balanced power plans. I tried that thing where you copy and paste other power... -
in Windows 10 GamingOther power plans are missing Theres only "balanced" power plan: Other power plans are missing on me. I saw some videos on the YouTube about that but none of them worked! I saw it worked on some people but at me instead of getting other power plans, I have 4 balanced power plans. I tried that thing where you copy and paste other power... -
MISSING POWER PLAN - Can only create a 'Balanced' power plan
in Windows 10 GamingMISSING POWER PLAN - Can only create a 'Balanced' power plan: Hi, I've had this problem for a while but thought I'd finally post a question. I have a Dell XPS 15 9570 and windows 11, and while I am trying to create a 'high performance' power plan, the option just doesn't show up. The only option I have available to me is to create... -
in Windows 10 Software and AppsMISSING POWER PLAN - Can only create a 'Balanced' power plan: Hi, I've had this problem for a while but thought I'd finally post a question. I have a Dell XPS 15 9570 and windows 11, and while I am trying to create a 'high performance' power plan, the option just doesn't show up. The only option I have available to me is to create... -
Power plan changing to 'Power saver' automatically
in Windows 10 Software and AppsPower plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power... -
in Windows 10 GamingPower plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power... -
in Windows 10 CustomizationPower plan changing to 'Power saver' automatically: Hi,I recently came across a problem with my performance on my laptop. In the end, I discovered that the power plans on my laptop Windows 10 are messed up real good.On every start or restart, every time I plug and unplug the charger, the Windows power plan is set to 'Power... -
balanced plan for power
in Windows 10 Customizationbalanced plan for power: cannot get high performance power plan as option on laptop, what do I do? powercfg change does not work. https://answers.microsoft.com/en-us/windows/forum/all/balanced-plan-for-power/b598c38c-df19-4005-93c0-148c12ed713e -
power plans are switching back and forth by themselves (from balanced to power saver mode)
in Windows 10 Performance & Maintenancepower plans are switching back and forth by themselves (from balanced to power saver mode): Noticed that when changing power mode that the plan modes are changing by themselves. Is this normal or what? https://answers.microsoft.com/en-us/windows/forum/all/power-plans-are-switching-back-and-forth-by/511f4b1f-d16b-4a32-b163-23ebc378363c
