Windows 10: Laptop Battery, Does It Hurt the Battery to Use External AC Power?
Discus and support Laptop Battery, Does It Hurt the Battery to Use External AC Power? in Windows 10 Support to solve the problem; I haven't used my laptop much yet, only a little bit to set up some bookmarks, wallpaper, etc. Every time I use it, I plug it into the wall. I'm at... Discussion in 'Windows 10 Support' started by Bigfoot, Oct 31, 2019.
Laptop Battery, Does It Hurt the Battery to Use External AC Power? - Similar Threads - Laptop Battery Does
How to use AC Power Adapter instead of battery
in Windows 10 GamingHow to use AC Power Adapter instead of battery: Hi,I have the *ASUS TUF F15 2021* I want to use this laptop while using the AC Power Adapter because it performs better than Battery mode while using the battery*So, is there a way to do that without decreasing the battery's lifespan?*... -
in Windows 10 Software and AppsHow to use AC Power Adapter instead of battery: Hi,I have the *ASUS TUF F15 2021* I want to use this laptop while using the AC Power Adapter because it performs better than Battery mode while using the battery*So, is there a way to do that without decreasing the battery's lifespan?*... -
my battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...
in Windows 10 Drivers and Hardwaremy battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...: I have a hp notebook da 1058tu laptop its battery is dead it never charges up the windows update asks for 40% battery. https://answers.microsoft.com/en-us/windows/forum/all/my-battery-is-dead-and-i-use-my-laptop-on-ac-power/cb183f9e-38c0-43af-a19e-b3c87270ee82 -
in Windows 10 Gamingmy battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...: I have a hp notebook da 1058tu laptop its battery is dead it never charges up the windows update asks for 40% battery. https://answers.microsoft.com/en-us/windows/forum/all/my-battery-is-dead-and-i-use-my-laptop-on-ac-power/cb183f9e-38c0-43af-a19e-b3c87270ee82 -
in Windows 10 Software and Appsmy battery is dead and i use my laptop on ac power battery % is 0 and it never fills up and...: I have a hp notebook da 1058tu laptop its battery is dead it never charges up the windows update asks for 40% battery. https://answers.microsoft.com/en-us/windows/forum/all/my-battery-is-dead-and-i-use-my-laptop-on-ac-power/cb183f9e-38c0-43af-a19e-b3c87270ee82 -
Battery not charging only works in AC power even battery is zero
in Windows 10 GamingBattery not charging only works in AC power even battery is zero: My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is initially at 44% when I know about this issue. When I connect the adaptor the laptop doesn't use the battery it automatically use... -
in Windows 10 Software and AppsBattery not charging only works in AC power even battery is zero: My laptop is msi Bravo 15. I know about the msi dragon center's charging modes this is not about that. My laptops battery is not charging . It is initially at 44% when I know about this issue. When I connect the adaptor the laptop doesn't use the battery it automatically use... -
Never using battery power in a laptop
in Windows 10 SupportNever using battery power in a laptop: I have a brand new laptop and I run it on mains power all the time (constantly plugged in) does this degrade the battery in any way as I have no way of taking the battery out because it is housed inside the machine. I have Googled this and have a number of different thoughts... -
Windows Laptop - Bypass battery on AC?
in Windows 10 CustomizationWindows Laptop - Bypass battery on AC?: Hi all, I have been wanting to ditch my high end desktop / low end laptop combo and replace it with a single high end laptop. I use it for business and occasional gaming, so when I travel it's very convenient to have all of my data with me without having to sync it manually...
does it hurt a laptops battery life if you dont charge the battery to 100% each time you recharge
,does using external power affect a laptop battery
