Windows 10: Laptop has no display and fan not spinning. But power LED is on
Discus and support Laptop has no display and fan not spinning. But power LED is on in Windows 10 Performance & Maintenance to solve the problem; Please help me. I have an Acer Aspire 3 laptop. It suddenly begun to exhibit no display whenever I turn it on sometimes. And when that happens, the... Discussion in 'Windows 10 Performance & Maintenance' started by DavidDeeehwa, Oct 3, 2020.
Laptop has no display and fan not spinning. But power LED is on - Similar Threads - Laptop has display
Everytime I switch on my laptop, the power light comes on and fan keeps spinning but no display
in Windows 10 GamingEverytime I switch on my laptop, the power light comes on and fan keeps spinning but no display: Everytime I switch on my laptop, the power light and the keyboard comes on but my laptop screen remains black. I just keep hearing the fan spinning. I can even feel the air. Please help I need my laptop urgently and I do not have the necessary tools to unscrew and remove my... -
in Windows 10 Software and AppsEverytime I switch on my laptop, the power light comes on and fan keeps spinning but no display: Everytime I switch on my laptop, the power light and the keyboard comes on but my laptop screen remains black. I just keep hearing the fan spinning. I can even feel the air. Please help I need my laptop urgently and I do not have the necessary tools to unscrew and remove my... -
Laptop fan spins terribly
in Windows 10 GamingLaptop fan spins terribly: Hi Team WindowsI have an issue with different laptop brands loaded windows 10 and windows 11.The fan spins terribly for a longer time while working on a spreadsheet or outlook, basically list resources consumed.This has nothing to do with low ram or low hard drive space.The... -
in Windows 10 Software and AppsLaptop fan spins terribly: Hi Team WindowsI have an issue with different laptop brands loaded windows 10 and windows 11.The fan spins terribly for a longer time while working on a spreadsheet or outlook, basically list resources consumed.This has nothing to do with low ram or low hard drive space.The... -
in Windows 10 BSOD Crashes and DebuggingLaptop fan spins terribly: Hi Team WindowsI have an issue with different laptop brands loaded windows 10 and windows 11.The fan spins terribly for a longer time while working on a spreadsheet or outlook, basically list resources consumed.This has nothing to do with low ram or low hard drive space.The... -
Fans not spinning
in Windows 10 GamingFans not spinning: I have some Rgb fans and they are not spinning it came with a fan hub and after a day it didn't work anymore. I am powering the fan hub using a sata connector but it doesn't work for some reason.... -
GL702ZC Black Screen and no fan, but power led is on.
in Windows 10 BSOD Crashes and DebuggingGL702ZC Black Screen and no fan, but power led is on.: I was using my pc yesterday for gaming playing rome 2. The laptop worked fine all day with no issue unitl 10pm then I exit programs and go to start and manually selected shutdown. One hour later,I get power led light up, but the screen is black and fans are not working.... -
Not entering sleep properly,- fan spin and led lights on.
in Windows 10 SupportNot entering sleep properly,- fan spin and led lights on.: Got an issue, sometimes when entering sleep mode windows and the pc (intel nuc) continue the normal procedure but seems to miss the last step. Instead of turning off the power button led it stays on, also the fan spins. Then the only way to turn it on is to hold in the power... -
Laptop fan not spinning.
in Windows 10 Performance & MaintenanceLaptop fan not spinning.: I have an Asus Rog G771JW laptop, I had it for almost 6 months now. Lately I have been noticing that when turned on it would make a loud scraping noise that would last ~10 seconds. But yesterday the fan completly stopped (from what I can hear) only the CPU fan is spinning...
