Windows 10: Laptop max brightness brighter when plugged to charger. less bright when on battery. which...
Discus and support Laptop max brightness brighter when plugged to charger. less bright when on battery. which... in Windows 10 Ask Insider to solve the problem; so i just realized that the display is brighter when the charger is plugged in. when the laptop is running on battery the screen is a bit less bright... Discussion in 'Windows 10 Ask Insider' started by /u/HansWurst31, Apr 5, 2021.
Laptop max brightness brighter when plugged to charger. less bright when on battery. which... - Similar Threads - Laptop max brightness
Laptop brightness flickering when plugged in?
in Windows 10 BSOD Crashes and DebuggingLaptop brightness flickering when plugged in?: My laptop screen brightness has just started flickering randomly dimming for a few seconds, then returning to normal for a few seconds, and so on, which only seems to be happening when it’s plugged in. It’s also had a problem for a while where it will run exceptionally slowly... -
in Windows 10 GamingLaptop brightness flickering when plugged in?: My laptop screen brightness has just started flickering randomly dimming for a few seconds, then returning to normal for a few seconds, and so on, which only seems to be happening when it’s plugged in. It’s also had a problem for a while where it will run exceptionally slowly... -
in Windows 10 Software and AppsLaptop brightness flickering when plugged in?: My laptop screen brightness has just started flickering randomly dimming for a few seconds, then returning to normal for a few seconds, and so on, which only seems to be happening when it’s plugged in. It’s also had a problem for a while where it will run exceptionally slowly... -
When plugged in, battery saver turns off, but the screen brightness stays at the battery...
in Windows 10 Software and AppsWhen plugged in, battery saver turns off, but the screen brightness stays at the battery...: For my laptop Lenovo Ideapad Slim 5i, I have these battery saver set so that it turns on at 20% and lowers the brightness of my screen when it turns on.Then, whenever I plug it in to charge, the battery saver turns off--this is normalMy main issue is that when the battery... -
in Windows 10 GamingWhen plugged in, battery saver turns off, but the screen brightness stays at the battery...: For my laptop Lenovo Ideapad Slim 5i, I have these battery saver set so that it turns on at 20% and lowers the brightness of my screen when it turns on.Then, whenever I plug it in to charge, the battery saver turns off--this is normalMy main issue is that when the battery... -
Brightness get more brighter
in Windows 10 GamingBrightness get more brighter: Hello guys I have asus vivobook 15 laptop when I turn on the laptop after that I want to click on the wifi and battery in the task Bar the brightness changes to be more brighter I don't know Why so if anyone have a solution please tell me how to fix it?... -
Auto brightness when plugged in
in Windows 10 GamingAuto brightness when plugged in: Recently re-set my computer back to factory, re-installed Windows 11, and now when I have it plugged in, if I change between a dark and light UI application, the brightness automatically adjusts. This does not happen on battery. I have checked everything possible and read... -
in Windows 10 Software and AppsAuto brightness when plugged in: Recently re-set my computer back to factory, re-installed Windows 11, and now when I have it plugged in, if I change between a dark and light UI application, the brightness automatically adjusts. This does not happen on battery. I have checked everything possible and read... -
Screen Brightness goes down when I plug in charger
in Windows 10 BSOD Crashes and DebuggingScreen Brightness goes down when I plug in charger: The other day I was playing a game, and when I would want more frames I would plug in the charger but then the screen brightness went down randomly even though the setting was all the way up. I tried to turn it down and it got a little bit brighter. Please help...
