Windows 10: Laptop not turning on but the power light is on how to fix?
Discus and support Laptop not turning on but the power light is on how to fix? in Windows 10 Gaming to solve the problem; My laptop is not turning on but the power light is on.how do you fix?pls help im charging it but its still not turning on.and its really hot.plss help... Discussion in 'Windows 10 Gaming' started by jakethemicrosoftuser, Oct 16, 2021.
Laptop not turning on but the power light is on how to fix? - Similar Threads - Laptop turning power
How to fix/ turn on my keyboards dynamic lighting
in Windows 10 GamingHow to fix/ turn on my keyboards dynamic lighting: My dynamic lighting on my keyboard on my laptop randomly stopped and i cannot figure out how to turn it back on and i have tried everything. Ive researched and nothing is helping i have a hp probook 430 G7. None of my keys are damaged.... -
Night light turns on after powering on
in Windows 10 GamingNight light turns on after powering on: Hi, I have windows 11 pro in my laptop. It is dual booted with ubuntu 24.04 . Whenever I start my laptop and open into windows or ubuntu, night light turns on automatically, even though the setting 'night light' is turned off. The night light will turn on after I enter the... -
in Windows 10 Software and AppsNight light turns on after powering on: Hi, I have windows 11 pro in my laptop. It is dual booted with ubuntu 24.04 . Whenever I start my laptop and open into windows or ubuntu, night light turns on automatically, even though the setting 'night light' is turned off. The night light will turn on after I enter the... -
Hp laptop wont turn on, long flashing power light.
in Windows 10 GamingHp laptop wont turn on, long flashing power light.: Had the computer for a year. Than after the warranty expired, the computer wouldn't turn on. Upon pressing the power button, I get no display, from the screen or hdmi output. But, power indicator and charger indicator light flashes for 8 seconds and turns off, repeatedly.... -
in Windows 10 Software and AppsHp laptop wont turn on, long flashing power light.: Had the computer for a year. Than after the warranty expired, the computer wouldn't turn on. Upon pressing the power button, I get no display, from the screen or hdmi output. But, power indicator and charger indicator light flashes for 8 seconds and turns off, repeatedly.... -
in Windows 10 Performance & MaintenanceLaptop not turning on but the power light is on how to fix?: My laptop is not turning on but the power light is on.how do you fix?pls help im charging it but its still not turning on.and its really hot.plss help... -
in Windows 10 Software and AppsLaptop not turning on but the power light is on how to fix?: My laptop is not turning on but the power light is on.how do you fix?pls help im charging it but its still not turning on.and its really hot.plss help... -
Turning power strip on now turns CPU power light on
in Windows 10 Performance & MaintenanceTurning power strip on now turns CPU power light on: Normally when I turn the power strip on in the morning I had to then turn on my CPU separately. For the past week when I turn on the power strip the CPU power button lights up, but I still have a black screen. I still have to press the lighted CPU power button briefly, and... -
power problem laptop won't turn on after sleep or shut down lights power light stays on
in Windows 10 Performance & Maintenancepower problem laptop won't turn on after sleep or shut down lights power light stays on: power lite and power button lite stay on after shutdown but windows doesn't shut down all the way. I have to press the reset button to get it going again I dont know what.s going on with this . HELP!!!...
